panasonic 50G10B
  • munirutech
    • Oct 2013
    • 72
    • Ghana
    panasonic 50G10B
    I have panasonic 50G10B if you plug the mains and switch it on there is no power or indicator light when I open the tv to check for voltages only 5v stb from the power supply to the main board ,the signal from the main board to switch the psu is not coming I suspected the main board but I want to know if anybody has come across this fault, I cant find some of the board here to buy I want to try to fix the faulty one
    Re: panasonic 50G10B
    How much electronics repair experience do you have? No standby light suggests a few possibilities:
    - 5V standby not reaching main board - broken wire/loose connector/cold solder/etc.
    - Panel/control MCU not working
    - Main board low voltage rail missing (such as 3.3V)
    - Software problem with main board/lock-up due to bad software (rare - would normally get standby light)
    - Broken LED light or connection in between
    You can get a full schematic of the A board (main video board) in the service manual:
    The power LED is controlled by IC1100, the SYSTEM MPU (GenX8) on the A board.
    Check the STB3.3V to it is present.
    You can check across the small ceramic capacitors near the IC (pins 63 and 65 for e.x.)
    Or you can check at pin connector A17 "FOR FACTORY USE" (normally not connected) pin #2 has 3.3V standby, and pin #1 has 5V standby. If you have 5V & 3.3V it looks like it could be a complex repair. If you have 5V & no 3.3V you're lucky, may just be a dud regulator or a shorted ceramic cap. If you have no 5V or 3.3V check all connections, wires, fuses, and solder joints along that tract.
    All readings are taken with black probe on chassis, TV powered ON.
    • munirutech
      • Oct 2013
      • 72
      • Ghana
      thanks, I will follows the tips and study the schematic and report back thankx again
      • sathya79
        • Jun 2014
        • Sri Lanka
        Hi Tom,
        Good I found this forum. Hope I can resolve my in Panasonic Plasma T.V (TH-42p..)
        On my Plasma T.V screen all of the sudden I can see Red or green pixels along with the image. there is no specific time or frequency for these pixels to appear. Some times it comes continuously all over the screen (along with the picture in the background) for about 30 sec and suddenly gets a clear picture and the same continues. But some times the picture is clear without any pixel issue for several hours.
        Is that a voltage issue or Aged screen? Your inputs please.
          Originally posted by sathya79
          Hi Tom,
          Please create your own thread with pictures of the problem and a full model number.
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • howardc64
            A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
            by howardc64
            Problem
            08-04-2024, 10:36 PM
