Sony Brava KDL40s4100 - Dead, No Standby
  • Nola_Gal
    • Sep 2013
    • 18
    Hey there guys, it's been a while since I've picked up another tv project, so It's time to consult the experts yet again.
    By the way, this forum has been a huge help to me in the past year. I really appreciate all the great advice & knowhow everyone has shared. Y'all rock!
    Today, I found a Sony Brava KDL 40S4100 (2008) on craigslist. The guy took great care of the tv, almost perfect cosmetic condition with the stickers still on. Original remote.
    The problem:
    According to the owner, the unit started to get slower and slower at turning on. The owner would unplug it, replug it, and turn it on. This worked for a while until it finally petered out.
    (To me, this sounded like something I might be able to fix. Power supply... Hopefully just some bad caps, so I went and got it.)
    It has no power at all. I plugged it in, pressed the power button manually. No clicking, no blinking, no sound, no standby.
    Opened the tv. No sign of any blown caps here, though I haven't taken the cover off of the A board yet. The fuse near the power supply is fine, reading '1'. Is anyone familiar with this model & maybe a common culprit for this particular problem?
    I checked the forum threads for the model in question. Everyone who posted with problems, had standby power to the unit. Nothing similar.
    I am by no means a tech or a pro, but I love taking things apart and figuring them out. I've fixed maybe 10 tvs. Trying to work smart here & get some good advice first. And again...
  • holmzy
    • Nov 2009
    • 99
    Re: Sony Brava KDL40s4100 - Dead, No Standby
    chech standby v. should be 3.3v. if no standby bad psu if yes bad av main. thats my experience
    • capkid
      • Oct 2010
      • 1339
      Sonys are notorious for bad main boards. The 4100 series is no exception.
      LG Plasma Mal-Discharge Correction Service
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        The fuse near the power supply is reading '1'??? If it is good and your DMM is on 200 Ohm scale. It should read '0' if the fuse is good. If on the continuity/diode scale the buzzer should sound if the fuse is good, too.
        • holmzy
          • Nov 2009
          • 99
          usually if there is power goes through the board but no standby etc it might be the big resistors with the built in fuse. had a old model sony that went out that way
          • capkid
            • Oct 2010
            • 1339
            I should have read through the issue more closely before I responded. I would guess that the caps in the PSU are fine, since Sony's are fairly reliable in that department (of course, testing would confirm). It does sound like a PSU problem. "1" on the meter normally means there's an open aka bad fuse in this case. Does the meter have fresh batteries?
              Check the DC Voltage right at the two legs of the main filter cap (450VDC rating cap) to see if you have about 165VDC or not.
              Which power supply board do you have?
              http://www.shopjimmy.com/catalogsear...ony+KDL40s4100
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • piposarcade
                Samsung UN50KU6300 dead no standby led
                by piposarcade
                01-04-2024, 01:33 PM
                Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                05-22-2024, 02:07 PM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
              • rabbituk
                Sony HCD BX7700dbi CMT flashing standby
                by rabbituk
                I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                02-11-2025, 05:05 PM
              • jacobtc
                LG C1 65'' dead standby
                by jacobtc
                I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                01-29-2025, 04:27 AM
