Toshiba 42XV505DB faulty mains power switch
    Interesting one here - mains power switch works OK but you have to hold it in for it to work! If it's released it will turn off immediately.
    For now, I just bridged switch, to disable it, but would be interested if anyone knows of a replacement switch part # or board. The board is PE0533H but that is going for £27+ on eBay which is excessive for a power switch. I guess it's a common fault.
    Re: Toshiba 42XV505DB faulty mains power switch
    foto?
    if it's a mains push-switch like on old tube tv's then Tidman or Grandata will have them.
      Here: http://www.ebay.co.uk/itm/ON-OFF-SWI...item3f37274c14
        tom try these a good company imo
        http://www.wiltsgrove.co.uk/product-...5504r2p2r2v253
          Hmm £POA though... will ask them.
          Don't mind putting a few quid into it, was only £33 on eBay.
          Seller said faulty power switch... I was thinking power supply or something, but nope... first time someone was dead right about a switch being bad.
            any probs with them i will get a you price as i have a cash account with them i use them for odd bits remotes etc.
              Does it give you a price? It's not showing me one.
                no but i have to phone them monday anyway so will get a price if you want, i also need to see why i cant log in since they have changed there web site.
                  i cant see it properly in the ebay pic - they are selling an assembly.
                  can you desolder the switch & post a pic - i may even have one.
                    TV is currently undergoing test (playing Avatar @ 100% backlight) so will do that at another time.
                    Yes that's an assembly. But it looks identical to Vince's switch as linked. I am going to look on CPC too.
                      tom in stock £1.88 for part £2.95 postsge plus vat.
                        not too bad I'll probably buy one then.
                          you know why they fail dont you,
                          people switch the tv off at night,
                          the daily arc as they switch it on/off burns the contacts because there is no supression cap.
                          i used to replace a lot of switches on large sony & philips tv's because of this.
                          you should warn the customer to leave it in standby at night and not be throwing the switch when they go to bed.
                            Yep - there is nearly no point to this switch anyway.
                            Power consumption of a TV in standby legally limited to not exceed 0.5W.
                            TV running = 220W
                            This means that leaving it on for just 1 hour is equivalent to over 440 hours of standby usage.
                            The cost of 1 year's standby usage = £0.57 (4380Wh, 4.38kWh, £0.13/kWh)
                            Person I bought it off said the switch has been replaced before at a cost of £70, he just got frustrated with it after it broke again.
                              £70 for a switch?
                              someone did well - what a rippoff.
                              it's shit like that that causes people to not get stuff fixed.
                              i think i would have charged £40 or less.
                                I would charge £20 if I disabled switch (bridging it, if customer decides they are OK without it), £35 to replace it. This is a refurb job though - buy 'em dead, fix them and sell them.
                                Also, the "new" switch had an Emos' TV part# sticker on it, so it wasn't even new, it was probably an already worn mains power switch...
                                  In the old CRT days I used to solder a 1.0mF 250v ceramic cap across the switch to reduce arcing and now I recommend a power strip with the little red switch to take of power in the night or when not at home to prevent power on issues that may develop if there is a surge or something.
