Samsung Plasma PN59D550C1FXZA Doesn't Power ON
  • karthur
    • Nov 2015
    • 150
    I picked this up at a yard sale and the owner knew nothing about it. Just knew that it didn't work. I get it home and sure enough it doesn't come on. Here is what I do see/hear.
    When its first plugged in, I can hear a click. It sounds like its from the power board. There is a red light on the front by the control panel that blinks 6 times. When I touch one any of the buttons on the front panel the red light will flash. I pulled off the back cover and looked at all the board. Nothing out of the ordinary. Nothing looks burned or damaged. On the power board (BN44-00445A), there are connectors CN801, CN802 and CN804. Below is the readings from these connections with it plugged into 120VAC.
    Any help to figure out why it will not power on would be much appreciated.
    CN801
    1. PS_ON - 0.17VDC
    2. STBY - 5.3VDC
    3. GND - 0
    4. 15v - 15VDC
    5. GND - 0
    6. GND - 0
    7. D5.3v - 5.3VDC
    8. D5.3v - 5.3 VDC
    9. GND - 0
    10. 15v - 15VDC
    12 . D5.3V - 5.3VDC
    CN802
    VS_ON - 0
    PS_ON - 0
    VS_OCN - 0
    GND - 0
    D5.3v - 5.3VDC
    D5.3v - 5.3VDC
    CN804
    Vs - 0.38 VDC
    15v - 15VDC
    Va - 0VDC
  • karthur
    • Nov 2015
    • 150
    Although mine is a BN44-00445A, here is a schematic I found for the BN44-00445C. Not sure how similar they are.
    • karthur
      • Nov 2015
      • 150
      I did more checking on the power board. When I plug in the 120v power, the PS_ON goes to 0.17vdc. Touching the power on/off button on the front panel doesn't cause the value to change. If I then unplug the power cord, the voltage increase to 2.96VDC. From what I have read, PS_ON >3 vdc = OFF and PS_ON<1vdc = ON.
      Its confusing to me that the PS_ON is .17vdc when I first plug it in. Shouldn't that be >3vdc until the power button is touched on the front panel. Does that mean the power board is the problem?
      • R_J
        • Jun 2012
        • 9732
        • Making Money
        PS_ON should be high (3v) to turn on QT409 transistor, normally the main board will hold that pin low when you unplug the power cord, the main board logic could temporarily show that voltage go high.
        I suspect there is problems on the Y-sus or Z-sus boards, likely shorted mosfets. with the tv unplugged, check the resistance across the VS and ground on the power supply, there may be a short or low resistance
        Search the model ( PN59D550 ) there are other threads on this model
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          • Electronics/classic muscle cars
          Change the 3 blue capacitors on the y-main (circled in red). Then try it. Bye the way, they are 10uf 50v each.
          • karthur
            • Nov 2015
            • 150
            I ohmed between Vs and ground. Goes up and down between 5k and 460k ohms. This is with all the connectors on the PS board plugged in.
            • karthur
              • Nov 2015
              • 150
              Thanks for that. I have located those components. Will try to get them off the board tonight. I have some old boards I might could scavenge some components.
              Kirk
              • karthur
                • Nov 2015
                • 150
                A few more observations:
                1. From what I have found from other YT videos, the 5 blinks of the front red LED is normal. The should mean the TV is ON.
                2. When I plug in the power, there is a green led on the board below the power board that blinks. 5 seconds on - 1 second off.
                3. If I unplug the Y Sustain board and then plug in the power, the Vs starts at 220VDC then slowly starts to fall. With the Y Sustain board connected, the Vs starts at 1.0vdc, then falls quickly to 038vdc.
                • R_J
                  • Jun 2012
                  • 9732
                  • Making Money
                  You likely have shorted mosfets on the Y-sus board, there may be other faulty components as well
                  • karthur
                    • Nov 2015
                    • 150
                    Could I replace those with these type capacitors? These are 10uf, 50v also. If not, I would have to order the disc type.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      You can do that. Make sure you put the positive sides where they have to go.
                      • karthur
                        • Nov 2015
                        • 150
                        I got those three caps off the board. All three measure 9uf. I will order the correct ones to go back, that way will will not be questionable. Plus I am not so sure the legs on the ones I have are long enough.
                        I checked all the MOFSETs on this board. The only one that I think is shorted is the D5014 (#SF10S600D2). That is, if I checked it right.
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          That is a diode. Both legs are the same. Measure the ground tab and each leg in diode mode.
                          • karthur
                            • Nov 2015
                            • 150
                            Bear with me... I am new to checking these components. I found the cutsheet on the SF10S600D2 Diode. Below is the reading I get on all the legs. Doesnt matter what leg I put the probes on, I get 0.00 on my meter in diode mode. I see two of these diodes on my board (D5014 and D5014). Both of them measure the same way. Could both of these be bad or is it not possible to check them in-circuit?
                            If I change to Ohms, I get 0.2ohms between 1 and 2 and also between 3 and 4. Again, same readings on D5014 and D5015.
                            • karthur
                              • Nov 2015
                              • 150
                              Am I checking that correctly? Since this is a diode, its seems that between 1-2 and 3-4 should read as open in one direction, but closed in the opposite direction.
                              • R_J
                                • Jun 2012
                                • 9732
                                • Making Money
                                I believe that dual diode is across other components on that board, so it is likely some of the mosfets are shorted. maybe Q5002, Q5003 etc.
                                There is an 8 pin plug near the large green electrolytics, on the board is a legend of the pinout. check the resistance between VS (7or8) and ground (3or5)
                                • karthur
                                  • Nov 2015
                                  • 150
                                  The 8 pin connector is CN5027. Checking between VS (pin7 or 8) and GND (Pin 4 or 5) reads 120k ohms. This is not a steady reading but gradually increasing.
                                  There are several of those under the large cooling fins. Q5001, Q5002, Q5003, Q5004, Q5005, Q5007, Q5008, Q5010, Q5020, Q5021, Q5022. When I check those with my meter in diode mode, with (+)Drain and (-) Source I get anywhere from 0.002 to .5vdc. not of them read 0L. IS this because they are shorted or because they cant be tested on the board?
                                  • R_J
                                    • Jun 2012
                                    • 9732
                                    • Making Money
                                    Many of those components are in parallel so it is likely only one or two are shorted, you would need to remove them one at a time to find the bad ones, if a mosfet is bad, it is likely the drive components could also be damaged
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      I went ahead and ordered a new replacement board. Plugged it in and TV works great now. If I get a chance next week I am going to pull out some of those Moffett and see how they read off the board.
                                      I found a replacement new board at ShopJimmy for $40. I thought that was very reasonable.
                                      • titomno2
                                        Surface Pro 7 1866 won't turn on...
                                        by titomno2
                                        Hi guys,
                                        Just have a surface tablet pro 7 (type 1866) with motherboard JALAMA_ICL_MB DV:2.0.
                                        Can't power on the surface tablet, no reaction on the button whatever the charger (working) is plugged in or not.
                                        After dissassembly I made a physical inspection without seeing any damaged component (nothing visible at least).
                                        Made measurement:
                                        With battery (low voltage 7.9V) the led D7013 is on (red)
                                        Charging seems odd and decided to let it apart and working only with DC input.
                                        With power supply 15VDC (white light on the charging cable).
                                        D7013...
                                        02-23-2025, 07:59 AM
                                      • DXseekerMO
                                        Samsung PN59D550C1FXZA, X-sustain, shorted fets from bad panel?
                                        by DXseekerMO
                                        Hello everyone, I hope you had a happy Thanksgiving! This TV comes from the free pile. It's a Samsung PN59D550C1FXZA. The complaint was the previous owner was watching TV, they heard a buzz/pop and lost video with audio present. After trying to re-boot the TV it appears to wake-up but isn't responding to the remote or key controls. No picture and no response to commands are confirmed.
                                        The health light indicated a problem on the sustain boards with a very long on-time when flashing. The main cap voltage comes up when plugged in then immediately drops off, so do VS and VA. I Tested...
                                        11-23-2018, 04:55 PM
                                      • mon2
                                        A1466 Macbook Air (Liquid damage repair)
                                        by mon2
                                        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                        Macbook AIR Model A1466 Diagnostic 09-01-2021
                                        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                        Problems & Resolutions
                                        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                        09-01-2021, 09:31 AM
                                      • delir66
                                        Eltek Flat Pack S HE. How to regulate voltage?
                                        by delir66
                                        Hi!
                                        I was in need of buying a high power 48v psu for a brushless motor driven pottery wheel project.
                                        I needed around 20a, and everything I found was more expensive than I first thought.
                                        I came across this unopened second hand Elteck Flat Pack S 48v 1800w for 80€. Had no clue about the brand, but was advertising 1800w 48v psu and looked pretty solid, so bought it. Was almost same price as a 20a lowest brand regular psu. (Afterwards looked for pricing, and they are pretty expensive).
                                        The thing has arrived and I have now realised it's kind of a moldular...
                                        11-15-2022, 01:03 PM
                                      • mikey5791
                                        Help needed to revive a blown power supply
                                        by mikey5791
                                        Got a used working computer running Windows 7 about 3 months ago. Two days ago, the power supply blew up with loud spark and i immediately shut off the power. It was an unknown brand Tatu (output 450 w).
                                        Upon opening, i found out the two transistors on heat sink 1are fried with burn mark. Replaced the two trans(E13007 type). Also checked if the surrounding components are affected. The diode seems to be working, i pulled one leg off and tested using diode test. One side got reading while swapping test probe shows 1(infinite).
                                        I also pulled out the nearest 2 small caps...
                                        03-17-2022, 12:53 AM
