SONY KDL-40XBR4 Tab bonding repair
    Second one today, bad bonding on the top right.
    Using Dealextreme thermal pad.
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: SONY KDL-40XBR4 Tab bonding repair
    You should get a new signature and call u the tab master.
    • daggeriiiiii
      • Jan 2015
      • usa
      I am thinking I have the same tab bonding problem with my Samsung. I wanted the problem to be an easy fix and have ordered a TCON, POWER SUPPLY BOARD, and the board with all the video inputs, but I doubt those are to blame after seeing many of the scenarios posted on various sites. Where is the best walk through on doing the TAB REPAIR ?
      • chrismurphy
        • May 2014
        • 251
        • australia
        I find your repair to be ok ,but i have also found this will not last as the material you used will eventually release the pressure on the tab
        I have used much harder material eg silicon tubing or tape that does not loose the tension over time .anyway good luck in repairing these tvs
          It lasts 2 years so far.
          My 52" SONY and SAMSUNG in Jan 2013
          https://www.badcaps.net/forum/showth...ht=tab+bonding
          How many have you done? Come back in two years and tell me if your are still working.
          https://www.badcaps.net/forum/showpo...&postcount=113
          • mmartell
            • Oct 2013
            • 3189
            Crap bud, I know the answer is buried in your posts somewhere but could you tell me what thickness of pads you got from Dealextreme ?
            • CapLeaker
              Leaking Member
              • 8349
              I just bought a kit with multiple thicknesses 0.5mm up to 3mm, as I use the stuff for other things too.
              • splitcrete
                • Dec 2012
                • 387
                • usa
                Good for you budm I do my bonds standing up also , better to work on.. I have a kdl-46xbr5 almost two years and still working good..
                  Hi mmartel, https://www.badcaps.net/forum/showpo...92&postcount=1
                  • mmartell
                    • Oct 2013
                    • 3189
                    Thanks bud, I guess the most important criteria is to cover the gap enough to put pressure on the bonds. I'm having a different problem, I have two cof's that are causing artifacts because they are running too hot. I've verified this by giving them a short burst of cold spray. Either the
                    • mmartell
                      • Oct 2013
                      • 3189
                      (cat stepped on the keyboard lol...)
                      Either the pad is not effective for this from the front or it simply cannot remove enough heat.
                      I'm going to try a piece in BEHIND the ribbon and then again from the top to make a COF sandwich, see if that helps.
                        Yes you can behind the ribbon to transfer the heat from IC to the chassis, but I think the IC will eventually fail, they do run hot.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Yes I think it is too late for this one. I just put a strip behind the ribbon and a couple over it and it definitely is improved but not cured. It's running too hot to be cooled this way.
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
                          • dkneyle
                            Sony KDL-46HX850 Can't upgrade/update firmware
                            by dkneyle
                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                            09-25-2024, 10:44 PM
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                            09-06-2024, 05:30 AM
                            Sony VAIO VGN-SR29VN/S S Specification for Upgrade or Repair
                            This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
