What capacitor is for 5volt standby?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I have no 5volt standby on my coby tftv4025 so im thinking would it be a bad cap for the 5volt standby? Or it is main board? I see nothing wronf visible on power supply
    Re: What capacitor is for 5volt standby?
    0V? Or just low...? (1~4V)
    0V = Unlikely to be bad cap
    Low = Possible bad cap
      AC main fuse is good? Are you getting 165VDC at the 2 legs of the main 450VDC filter cap?
      If you do and do not see any damaged/burnt components, then unplug the TV and try heating up the two small start up caps C205, C206 by the standby power supply section using hair dryer for a couple minutes to see if the 5V will come on and has steady 5V.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        yes it was low volt, the power led light on outside ov tv wasn't even on, I was thinkn bad startup cap
          If the voltage is unstable bad startup cap is a possibility. If it is stuck at one voltage, then it is more likely to be a bad output capacitor, excessive load, or bad voltage reference IC.
          • mattstolte
            • Dec 2013
            • 612
            • usa
            so I have 5volt standby but my outside led light isn't even on
              What changed? You didn't have 5V standby before? Have you tried with the main board in and out to see if there is any change?
              • mattstolte
                • Dec 2013
                • 612
                • usa
                I think the what it was before my negative probe was bad now I got a new one, so there is 5volt standby but no led light on outside, possibly bad main? now what type of change with main board would I do? and what would I look for?
                  Change with main board? Do you mean checks?
                  Check any fuses (if present), check all voltage regulators and DC-DC converters, and check if the processor is getting excessively hot.
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
                  • chth96
                    How can I test non-polarized capacitor?
                    by chth96
                    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                    06-02-2024, 07:31 PM
