I have no 5volt standby on my coby tftv4025 so im thinking would it be a bad cap for the 5volt standby? Or it is main board? I see nothing wronf visible on power supply
What capacitor is for 5volt standby?
Tags: None
Re: What capacitor is for 5volt standby?
0V? Or just low...? (1~4V)
0V = Unlikely to be bad cap
Low = Possible bad capPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
AC main fuse is good? Are you getting 165VDC at the 2 legs of the main 450VDC filter cap?
If you do and do not see any damaged/burnt components, then unplug the TV and try heating up the two small start up caps C205, C206 by the standby power supply section using hair dryer for a couple minutes to see if the 5V will come on and has steady 5V.Never stop learning
If you do and do not see any damaged/burnt components, then unplug the TV and try heating up the two small start up caps C205, C206 by the standby power supply section using hair dryer for a couple minutes to see if the 5V will come on and has steady 5V.Comment
If the voltage is unstable bad startup cap is a possibility. If it is stuck at one voltage, then it is more likely to be a bad output capacitor, excessive load, or bad voltage reference IC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
so I have 5volt standby but my outside led light isn't even onComment
What changed? You didn't have 5V standby before? Have you tried with the main board in and out to see if there is any change?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I think the what it was before my negative probe was bad now I got a new one, so there is 5volt standby but no led light on outside, possibly bad main? now what type of change with main board would I do? and what would I look for?Comment
Change with main board? Do you mean checks?
Check any fuses (if present), check all voltage regulators and DC-DC converters, and check if the processor is getting excessively hot.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
I know that these capacitor will not last as long as nichicon capacitor...-
Channel: General Capacitor Questions & Issues
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
by chth96a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
Is this ESR value of polymer capacitor correct?...-
- Loading...
