50HP66 thin vertical line
  • n3lka
    • Jan 2014
    • 84
    I have a 50HP66 I just fixed the ysus. I never saw the picture before repairing the it. There's a thin blue line going down the screen towards the middle. I've read in some instances the display is starting to go with this issue, anyone heard different, or should I just part it out now?
    I would try to get a picture, but it's only about a pixel wide and hard to see.
    Thanks,
    Brian
    Re: 50HP66 thin vertical line
    Bad plasma panel is the likely cause. LG panel inside?
    • n3lka
      • Jan 2014
      • 84
      I'd have to open it up again to see, most likely, using LG parts. ....oh well, I can part it out and make my money back on the ysus alone.
      I bought a hakko desolder gun, made the module replacement much easier.
      Uggh,
      Brian
      • n3lka
        • Jan 2014
        • 84
        Yup, LG panel, there are more lines starting to appear. I tried to reseat the associated ribbon cables, no change. Fortunately I can part the zsus and ysus boards out and not be in the hole.
        Thanks,
        Brian
        • Shinju
          • Mar 2014
          • 1239
          Just for kicks, try cleaning and reseating the buffer ribbon cables at the top of the panal.
          I have a Sammy PDP sitting here that had a 3" void with multi colored lines going halfway down the screen and all it ended up being was a loose buffer ribbon cable. After I cleaned the afflicted cable and reseated it. The void was gone and it's been working fine ever since.
          On thing you might want to try if there are air perfs at the top of the back she'll take a small wood dowl or of you can a longer toothpick and gently rub the ribbon cables near the line and see if anything changes.
          But as tom says that's a pretty good sign the panel is shot.
          Good luck!
          • Shinju
            • Mar 2014
            • 1239
            Derp, you just posted as I was typing my novel lol. Disregard what I said then!
              HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
              This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
              09-06-2024, 06:50 AM
            • Raulnn
              Hisense LTDN40D36EU thin black vertical line
              by Raulnn
              good evening!!! I have this tv with a line that occupies 1 or 2 pixels in width. it has a solution? Can you do a test to find out if it's a panel or something else? Having the tcon integrated into the panel makes everything difficult. I have pushed on the flex attached to the panel, on both sides and there are no changes. I don't know what else I can do... the integrated ones that go on the flex get hot, but without burning yourself if you put your finger on it. to see if someone can help me. I attached a detail photo of the line. Thanks in advance...
              12-30-2022, 05:45 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
              HP mt44 Mobile Thin Client Mobile thin client Specification for Upgrade or Repair
              This specification for the HP mt44 Mobile Thin Client Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client boardview and mt44 Mobile Thin Client schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
