Emerson LC320M2F No Power
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Good day All. I am trying to figure out what is happening with this LCD TV. When I received the set it was not powering up. Upon removing the back cover I discovered the fuse was open and a series of components were open or shorting. I went ahead and replaced the burnt components from a kit aqired from e-bay. These parts burnt out immediately when I replace the old ones and applied AC. So I went ahead and purchased a PSB from e-bay. I got the new board and now when the AC is applied I get no stand-by light and press the power button I get no response.
    I am getting 5V (4.85V) from the ALL %V Test point. All other Test Points are low. e.g the 24V rail is 9.86V
    Could it be the Main Board is defective and so not sending the P-on signal to turn on the PSB??
    Thanks for any assistance.
    Andy.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Emerson LC320M2F No Power
    Oh! There is a typo error. It is ALL 5V (4.55V) and not %V. Sorry if I confused everyone.
    • bammbammfran
      • Apr 2014
      • 476
      some good pictures would be helpful
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Pics of the Pwr Sup Bd upper side and lower side and main Bd.
        • bammbammfran
          • Apr 2014
          • 476
          did you check the voltages using your positive probe on the silver ends of the diodes that you have marked?
          Did you also check them with the main board connected and with the main board disconnected ?
          Which one has 5 and which has 9.xx and is the 9.xx there if the main board is unplugged
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            OK. I would re-check the voltages I got and post them. What I remember is the the ALL-5V = 4.45 and the ones that are marked as 24V = 9.75V. This is with the pwr supp bd disconnected from the Main Bd.
            Really grateful for you replies.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Had a little problem with the Crude Distillation Unit at work. Some quick thinking and sleek troubleshooting skill got it back on line in avery short time.
              OK. So I decided to take the easy way out and went ahead and purchase from e-bay ($15.00USD) for a Main Bd. I figured at that cheap price it was a good investment, if it works.
              I will let you know how that worked out when I get it.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Ok. So I got the new (used) Main Board yesterday. Stuck it in and she fired up. Just quickly closed it up and delivered to the owner. So this time the Pwr Sup and Main Bds went out. Thanks bammbammfran for your interaction. Bless, Andy.
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • swimllamaswim
                  Precision 5550 LA-J191P No Power, Burnt ISL9538
                  by swimllamaswim
                  I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
                  Here are the voltages measured at that chip:
                  To note, DCIN at Pin 17 is low,...
                  09-21-2025, 12:26 PM
