Panasonic tc-p55st30 buzzing flickering upper screen
  • scoobyroo
    Confused
    • Jun 2010
    • North America
    Hello all! Ive been browsing the forums off and on over the years and finally have a problem of my own, I truly appreciate any suggestions or pointers in the right direction.
    My apologies in advance if this is a bit long winded, I just wanted to be thorough.
    I've had this problem once in the past, sadly I can't remember for the life of me the board that failed (maybe audio?) but the technician that came out ended up swapping all of them under warranty after finding a number had been taken out in the process. The tv itself still works fine however in the past month or so its been starting to flicker (the brightness seems to go up and down quickly with dim lines showing once in awhile, though never actually loses the image) along the upper half of the screen, it started off very faintly and took awhile to show but has gotten progressively worse since then, now starting almost immediately with the tv being turned on, accompanied by a faint buzzing in the upper left hand corner. Occasionally the whole screen will do the same after a bit of time has passed along with the sound cutting out but I'm not entirely sure if that's the tv itself or our cable box. Since then Ive just kept it off until I find out more. I've grabbed a copy of the service manual and noticed a board marked ss11 is the closest to the noise, I've done a bit of searching as well and have seen a loose screw can also make the same buzzing I'm experiencing, but does it also cause the flashing/failure I saw in the past as well? While it would be really awesome if the fix was that simple, I figured I should ask before I go taking the thing apart. Also, when I do end up opening it, are there any other common failure points on these tv's that should be looked into?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p55st30 buzzing flickering upper screen
    If it's buzzing and flickering I think it would be worth checking out that all the screws on the SS,SC and SD/Su boards are all secured. Flickering may be due to a poor earth because of a loose board.
    There is a model which starts arcing and blows the SS board but not sure if it's this series or the next years models.
    If it's out of wty, not much to lose.
    • scoobyroo
      Confused
      • Jun 2010
      • North America
      Thankyou for the confirmation, I just got home tonight but I'll go ahead and give it a shot and see
      • tw2005
        • Oct 2011
        • 6458
        Not really confirming anything other than if it was me I'd open it up and have a good look at this stage.
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • spleenharvester
          Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
          by spleenharvester
          I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
          • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
          • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
          • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
          • Display and buttons all behave normally aside from the
          06-27-2025, 07:49 PM
        • reessi
          ACER BM320 Monitor - Horizonal Flickering Lines After a While
          by reessi
          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
          They are black on the right and gradually fade to nothing on the far left.
          They start either after 5 mins or up to 2 hours after so annoying for testing.
          They flicker continuously very fast! With a slight pause milli-second every second.
          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
          I tested each half by removing the first the left flex from...
          06-03-2025, 09:58 AM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • 0AiVeN0
          Panasonic TX-L42E5E flickering LED
          by 0AiVeN0
          Good day guys,
          I am trying to repair this older model of LCD TV Panasonic TX-L42E5E for my family. This older type is known for its single edge LED strip technology.
          First of all, it worked for many years and then TV just goes to stand by suddenly. No RED light blinks, just turned off and I can repeatlly trying to turn on, nothing, sometimes its start but a few seconds turn off again.
          So I inspected componencts, found nothing (like capacitors etc.) decided to replace edge LED then. After replacing LED TV started to work and can be switched on with no problem,...
          04-03-2021, 11:31 AM
