Samsung LN55C630K1FXZA Black Screen
  • sekellogg
    • May 2014
    • 8
    Samsung LN55C630K1FXZA 55 Inch.
    Sometimes when I turn it on it is fine, but much of the time the screen will come on for a few seconds and then it goes black. There is still sound. Reading through these threads I checked the picture by putting a flashlight against the screen and I can very faintly see the picture.
    I have seen the recommendation to replace capacitors for other Samsung's with a similar issue, but mine look ok. And suggestions?
    Thanks in advance!
    Steve
    Re: Samsung LN55C630K1FXZA Black Screen
    Post good clear pictures of the back side of the TV so we can see what we are dealing with first.
    • sekellogg
      • May 2014
      • 8
      Attached.
      Let me know if there is something else you need to see.
        Pictures of the whole back side of the TV so we see all the boards. Then straight shot pictures of each board.
        • sekellogg
          • May 2014
          • 8
          Please let me know if more are needed. As you can tell, I am a novice here.
          Appreciate your patience and time.
          • sekellogg
            • May 2014
            • 8
            Should I go ahead and try replacing the capacitors from the power board?
              You may have bad power supply/inverter board, or Balance board (the big log board where lamps are connected to), or bad lamps.
              Unplug the unit from the outlet, then remove the cable between the power supply and the main board, then apply the power and see if the backlights will stay on.
              Also need the P/N of the power supply/inverter board, it should be something like BN-XXXXX.
              • sekellogg
                • May 2014
                • 8
                Something to note as I have been looking at this today... It seems the picture does not go black as often if I power on the tv with an unplugged source. The picture stays telling me there is no source plugged in.
                I will try your suggestion and get you the P/N.
                Edit to add: The main board would be the board with the HDMI connections?
                  "The main board would be the board with the HDMI connections?" Yes.
                  • sekellogg
                    • May 2014
                    • 8
                    With the main board unplugged from the power supply, the tv does not turn on.
                    The BN is BN44-00342B
                    • HTR-Informatique
                      by HTR-Informatique
                      02-09-2025, 06:51 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • totof
                      Samsung UE50KU6070 black screen
                      by totof
                      I have my TV model UE50KU6070 which I am trying to repair.
                      BN41-02528A / BN94-10800C motherboard.
                      If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                      When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                      After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                      09-26-2022, 02:34 PM
                    • VcemPzd
                      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                      by VcemPzd
                      Hello everyone !
                      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                      04-28-2025, 10:14 AM
