Sceptre X322BCB0359
Re: Sceptre X322BCB0359
Well that did not work.
Like I said I have 2 of everything and I cant get it to do anything by using any combination of parts.
Tough one hereComment
Ok everyone here is what I have so far. If anyone has an idea please let me know.
Picture one
Label / When on / When off
12v / 12.51 / 0
12v / 12.51 / 0
gnd
gnd
5v / 5.08 / 0
5v / 5.08 / 0
gnd
gnd
5vsb / 5.09 / 5.09
ps_on / 4.56 / 0
BK_on / 4.97 / 0
ADJ / .24 0
NC
GND
Picture two
24v / OL / .01
24v / OL / .01
gnd
gnd
Large green Cap never goes above 160VDC
I did try to turn the unit on with out the T-CON board connected and same result.
Dont know if all this helps but here it is.
Attached Filesif you find these attachements useful please consider making a small donation to the site
Your mother board is sending all the correct signal to the power supply board.
ps_on / 4.56 / 0 Good
BK_on / 4.97 / 0 Good
ADJ / .24 0 Good
But the high voltage circuit for the backlights will not work until you get about 360~400VDC on that cap.
That high voltage is generated by the transformer T301 which is driven by the two black power MOSFET's (there is white glue between them).
So I need the good straight shot picture of the bottom side so I can look at the PFC circuit section to see what IC uses for the circuit.Never stop learning
How is this oneYour mother board is sending all the correct signal to the power supply board.
ADJ / .24 0 Good
OK, a straight shot of the top side also.Never stop learning
OK, get the P/N of that U201.Never stop learning
This is what your power supply has:Attached Filesif you find these attachements useful please consider making a small donation to the site
We need the number so we can look up the spec sheet to get the pin out to test the voltages and resistance.
How about the second board? You may have to use alcohol to rub on the top to see the printing. I will not able to do much without the P/N and the spec sheet.Never stop learning
Good, that is the PFC IC I suspect.
Just the board by itself, check the resistance reading between pin 6 (Ground) against all other pins, make sure to report if the readings are in Ohm, K Ohm, or M Ohm. I will not be surprised if this IC is bad.
We are getting close to fixing this board. I hope you have the right tools to do SMD component replacement.Attached Filesif you find these attachements useful please consider making a small donation to the site
Here is example of the failed PFC circuit:
Read post 41 and later:
https://www.badcaps.net/forum/showth...t=L6562&page=3Never stop learning
Ok here is what I have.Good, that is the PFC IC I suspect.
I tested both boards
PIN1 9.696K
PIN2 14.991M
PIN3 42.874K
PIN4 299.64
PIN5 21.974K
PIN7 9.22K
PIN8 THIS IS WIRED IT SEEMS TO START AROUND 13M OR 12M AND DROP ALL THE WAY TO .56 AND KIND OF FLUCTUATES UP AND DOWN SOME.
THE OTHER BOARD GOT ABOUT THE SAME READINGS.Comment
OK, we need to check pin 8 (VCC) to see if the IC is getting >12.5VDC typ. to run.
You will use the negative leg of the main filter cap (450VDC cap) as the Ground ref point. You must be REAL CAREFUL because you are working in the primary side, it is not going to be easy since the part is on the bottom side. You should plug the board into GFI outlet to protect yourself.Never stop learning
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
