XBR-75X940D : Alive but no Backlight, Seeking Advice...
  • willis6732
    • Feb 2023
    • 41
    Hello, Tv Has no Backlight (or Sound that i know of)
    Tv Turns on flashing Orange/Green, and then turns to white with remote and can be turned on and off.
    Was also able to update firmware with no change.
    The TV had a Burnt LED Driver IC on the Main Power board, Both main power boards have been replaced.
    I would like to test the backlights on this TV without opening it up. I am confused by all the ribbon cables coming off the LED Driver board
    I have a LED Tester...
    Ribbon cables E,F Look totally different than A,B,C,D,G,H,I,J
    I tried to probe around with beep mode to find any ground near the ribbons cables and i did not...
    I dont want to damage anything...If i dont get help here then i guess the next step is to open the panel or order a replacement LED Driver board...
    Thanks for any help in advanced...
    KW
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4540
    • Italy - Milan
    This is a local dimming set, the leds are controlled individually or in a short set, this means each channel is outputting very low voltage, thus i don't know how do you refers for burnt led driver ic on the main psb, can you fire out a photo of both replaced boards? You cannot test all the led channels because is not needed, it high unlikely so a few leds can block the entire set. The first thing to do is to test the couple main board / lcd panel, to do it you can watch the screen with a flashlight, but i guees you have not an image, a faulty backlight might be indicated by a status led error code. The amber green indication instead is commonly a bad pairing mb<> tcon, if none of them are been replaced, then there is a bad tcon, check its fuse or presence of input power on it
    • Diah
      • Feb 2013
      • 6568
      NOTE: I have removed the offensive opening line from this post.
      you have 8 strips ABCD GHIJ . each strips had 2 zone so all in total are 16 zones , E & F are LED + which they are connect to current limit R sync , each are provide 8 zones
      even you will test with LED tester you will not able to remark if they lit on.. cause of the limit counts of LED units at different position.
      disconnect the ribbon cable between MB and LED driver boards will guide you if they all will turn on... in case the main boards send BL_on to PSU
      NO sound mean too Optic audio port not lit on red,,, this case says MB didn't start high complete.
      work around disconnect the Bl_ON cable from PSU socket and connect the pins of it with Power--on via 1KR
      • willis6732
        • Feb 2023
        • 41
        Hey thanks guys...
        Re: Davi.p
        Ive never seen any picture even with a flashlight. No sign of backlight on the back or if i push on the panel. I can investigate the Tcon more...
        Re:vDiah
        ""disconnect the ribbon cable between MB and LED driver boards will guide you if they all will turn on... in case the main boards send BL_on to PSU""
        This Model has a DPS board between the MB and LED Board. If i unplug DPS to LED board there is no sign of backlight
        and actually yesterday i had accidentally left the DPS to LED board unplugged whe i went to update it. Not sure if that helped but it seem to update doing quick white repetitive blinks...
        "work around disconnect the Bl_ON cable from PSU socket and connect the pins of it with Power--on via 1KR"
        Im guessing you meant BL-ON? There is a BL-On line going from the Right side Power board to the DPS board. and a BL-ON line going between the 2 power boards.
        I can try that... Feed the DPS board BL-On signal with Power--on via 1KR...
        See picture:
        The power supply board on the Far left has a "Boost 1channel white LED Driver for large IC" on the back of it. This IC was burnt and left burn marks on the frame too...
        Thats why i am messing with the LED driver board now, cause i thought this burnt chip was a clue to look that way....
        PS: The LED Driver board has a green LED that flashes 7 quick 1 long.
        • Diah
          • Feb 2013
          • 6568
          you need to disconnected the one i remarked with red. and on the PSU socket after you disconnected simulated stand alone test , standby 3.3V with 1KR to power_on and T-con_con and BL_ON you may have other label printed
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4540
            • Italy - Milan
            _--------------
            to the OP: first, wow, what a beast of tv set, i love these ones with high complexity..
            one thing i do not understand, the datasheet says DCDC converter but i see no one of these on that board, it is a ACDC PS with PFC, i see also an intermiddle board called FRC, before the tcon, one has to check voltages on it, first input 12v, then step down dcdc (on the coils), eventually linear dcdc, the supposed error code blink on the led board can be a broken led board, or a broken main board that cannot communicate with that, the STM32 microcontroller seems to have function (at least diagnostic), you might have to check one by one those lot of 4 pin ic that resembles dual mosfets, the input rail is the same, it's enough one shorted that the power rail is down.. question: the burnt ic you say was on the primary or secondary side of board?.. well, with pink hearts painted on the boards, i think one female baby tried to repair the thing... i joke..
              • 115474
              Davi.p - I see who started the argument (which i have now deleted) but please do not respond the way you did. Instead email the admin.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4540
                • Italy - Milan
                Ok moderator sorry i will do..
                to the O.P. .... i have never opened such a beast, i think the backlight is organized like this, it has the huge amount of 1024 led, wow, wonderful ------ (i don't recall the term), them are organized in a grid of 64x16 and are controlled one, or 16, per time in sequence, the sot23 ic are probably dual protection diodes, i don't know if them have to be checked each one, one leg is gnd, the other two must not be gnd otherwise are at fault.. the gnd leg could be the one near the vias because the other two are on the traces of the led channels..
                • willis6732
                  • Feb 2023
                  • 41
                  Thank you for the instructions. I am not super clear on the second instructions, but ive got as far as i could understand.
                  To clarify more the symptoms are... when pugged in, no light for 10 seconds (Except Green LED on LED board), then orange-green alternating, then 10 seconds later the remote works and the light turns to white and the light can be turned on and off with power button on remote.
                  I unplugged the 3x connectors that you marked with the stars in image... and same symptoms
                  Next I cut the BL-ON wire and connected the the DPS/MAIN side to a 1K and then to POWER_ON.
                  (Shown in Pic)
                  The connector also has:
                  TCON_ON
                  STBY_Voltage
                  It sounded like you were saying i could grab power from either POWER_ON or STBY_Voltage
                  What do i do with STBY_Voltage?
                  And i think you were saying i shloud also apply power to TCON_ON with a 1K resistor as well..
                  Not sure if that is correct or not.
                  I've included images of all the connectors on the PSU boards
                  I appreciate your time in helping out.
                  Thanks again
                  K
                  • Diah
                    • Feb 2013
                    • 6568
                    apply hard reset to the set via the TV keys
                    • Borse2008
                      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                      by Borse2008
                      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                      • There’s
                      07-15-2025, 04:55 AM
                    • osrex
                      LED DRIVER KEEPS DYING
                      by osrex
                      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                      i have no datasheet at all for the LED lights, all i have is its length.
                      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                      05-05-2025, 03:36 PM
                    • Cooperr
                      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                      by Cooperr
                      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                      10-21-2025, 01:11 PM
                    • Ven
                      Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                      by Ven
                      I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                      The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                      I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                      If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                      07-08-2024, 09:32 AM
                    • Phad
                      Seeking help and advice to remove bios admin password – HP ProBook 4520s
                      by Phad
                      Dear All,
                      Hope that this post is at the right place of the forum.
                      I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                      The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                      As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                      After...
                      11-10-2021, 12:05 AM
