Sony KDL-19M4000 Dead
  • RanZim
    • May 2014
    • 6
    I have a Sony KDL-19M4000 Flat Screen that is dead -- no standby light.
    Fuse F101 checks good.
    Got servioe manual. On power supply board (G boord) connector CN101 has no voltages present. Manual has pictorial/layout of G board, but states that schematic is not available.
    Traced out some of board (Wow! Never saw so many filters and flash gaps.) and have continuity from line cord connector to BD101 (bridge rectifier??).
    I'm flying blind here.
    Is anyone familiar with this board? Or have an idea on how to approach this problem based on other Sony TVs?
    Thanks.
    • 31254
    Re: Sony KDL-19M4000 Dead
    fotos?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Any stdby 5v from PSU to MB?
      --With no light--I'm guessing not....
      TELEFIX
        Is this the board?
        http://www.shopjimmy.com/sony-1-857-032-11-g-board.htm
        Top view
        http://www.shopjimmy.com/media/catal.../185703211.jpg
        If it is, check the DC voltage right at the two legs of C101, C102 main filter caps.
        • RanZim
          • May 2014
          • 6
          Thanks for the quick replies guys.
          To Budm's questions --
          Yes, that is the board.
          Measuring C101 and C102, all leads to ground are zero. However across the leads of each cap, I read 159 Vdc.
          Also. the voltages on CN101 are not exactly zero. There are --
          on the 5.5v pins --> 1.5 to 2.0 vdc, varying
          on the 2.5v pins --> 1.0 vdc
          on the 12v pins --> 2.5 to 4.0 vdc, varying
            "Measuring C101 and C102, all leads to ground are zero. However across the leads of each cap, I read 159 Vdc." The is correct voltage, BTW, when you check the voltage on the Primary side (HOT side) of the circuit, you do not use the chassis Ground (safety ground) as the ground ref point, you use the negative leg of the main filter cap as the ground ref point, that is why I indicate to measure the voltage right at the two legs of the main cap.
            It sounds like you have bad startup caps (C104, C108 on the right of the big cap) in the primary side.
            Try heating that area for a few minutes with hair dryer, then apply the power to the monitor to see if it will come on.
            • RanZim
              • May 2014
              • 6
              Thanks for the reply, Bud. (I've been on the road a few days.)
              Yes. I just automatically measured the voltage to chassis ground. But once I saw the peak voltage across the cap, I knew I was on the line side of the circuit.
              I tried the hair dryer idea per your directions, but no change -- still dead.
              I also was attempting to trace that part of the circuit (and draw a schematic) from the foil side of the board. But it's rather involved.
              Would appreciate any other ideas/approaches you might have.
                You need to measure -across- those caps i.e. red on positive lead of cap, black on negative lead. If you like you can also place the black lead on the negative of the 450V cap which can be easier.
                • RanZim
                  • May 2014
                  • 6
                  Thanks for the response, Tom. But that really wasn't an issue. I was just explaining why I measured to ground first, and then across the cap.
                  After thinking about the symptoms, particularly the varying voltages (see earlier post), I'm beginning to think this may be either an auto-shutdown problem, due to an overload on one of the supplies, or a kick-start issue. Of course without a schematic, the debug/analysis is that much harder.
                  Has anyone had any experiences with these types of problems?
                  Has anyone successfully (and safely) operated this PSU board without a load?
                    You can run the board by itself since it is an always on power supply. Do you have cap meter to measure the capacitance and meter to measure the ESR of the cap. At this point I would try replacing those start up caps first. You can load the 5V power supply with 10 Ohms 5W resistor to simulate 500mA current draw.
                    • RanZim
                      • May 2014
                      • 6
                      Thanks Bud. I got sidetracked with car repairs and plunbing repairs. Am now finally able to get back to the TV issue.
                      No, don't have an ESR meter. But I should probably buy or build one since there are a number of antique radios people want me to look at. (Any suggestions?)
                      In the meantime, I will replace those two startup caps.
                      I'll let you know how it works out.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • jb_Bak
                        by jb_Bak
                        CN6401
                        Pin 01 NC
                        Pin 02 NC
                        Pin 03 "BL_ON": 0V
                        Pin 04 "N/C"
                        Pin 05 "STBY 3.3V": 3.5V
                        Pin 06 "GND": N/C
                        Pin 07 "AC_OFF"...
                        09-27-2021, 04:52 PM
                      • k370
                        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                        by k370
                        I have a NM-A321 board that is dead, with no power at all.
                        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                        • +3VALW
                        • +5VAUX
                        • 1.2VSUS_PWRGD
                        • 3VALW_PGD
                        • 1.05VAUX_PWRGD
                        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                        09-23-2024, 11:57 AM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • delpiero3
                        Sony Vaio SVS MBX-261 board failure
                        by delpiero3
                        Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                        Nevertheless, let's say, i don't come as a total beginner.
                        I have this old laptop, which suit perfectly my needs, with the...
                        10-29-2024, 06:16 AM
