LG model 32LD350 weird problem
  • techietech2
    "OLD EX TV TECH
    • Jun 2013
    • 31
    Hey guys,
    I recently purchased an LG 32 inch tv with a bad screen for 20 bucks. It had a bad lcd, but that did not bother me because I had another one in the shop that was brain-dead.
    The one that I bought worked fine except for the screen which had streaks across it horizontally near the top, I assume data lines broken or something. I took the other set apart and got a real surprise. The main boards looked identical, but the power supplies were totally
    different. The one I bought seems to be a combo power supply and back light inverter, where as the one I had already had a seperate power supply and back light inverter board. Also the one I had already, had a standard tcon board, but the one I bought had a strange el-cheapo tcon board attached to the lcd. There is only 3 months between the manufacturing dates on the backs of the sets, and they looked like identical sets. When I switched out the main boards, the set came on, and I thought all was ok, then the screen blinked off, then back on a couple of times, and shut down. I noticed that the screen was about half size, both horizontal and vertical.
    Nothing I do can change anything about the on-off pattern.
    The crazy part is that the main board worked fine in the other set, and seems to be the exact same board, with just a few differences in the model numbers.
    I am attaching a set of pictures of the boards in this set. Pictures 1 thru 4 are from the old original set, and pictures 5 thru 8 are from the new set I bought.
    If anyone has any idea of what to do to reset this thing, or maybe reload the software or something, please advise me. thanx...........
  • techietech2
    "OLD EX TV TECH
    • Jun 2013
    • 31
    Re: LG model 32LD350 weird problem
    anyone got any ideas on this????
    • R_J
      • 9535
      The main boards are most likely different, different firmware, what are the complete service code numbers of both tv's, should be something like 32LD350-UB.CUSDLH
      also what are the part numbers on the barcode labels
      • techietech2
        "OLD EX TV TECH
        • Jun 2013
        • 31
        I'm not in my shop right now, but I know the old set's service code number is 32ld350-ub.cuswlh. (manf date may-2010) Not sure that I saved the other set's back, front and screen plastic parts. I will try to post the barcode labels of the boards later.
        thanx
        • techietech2
          "OLD EX TV TECH
          • Jun 2013
          • 31
          ok,
          the old dead board barcode is m0201330 LGEEBU61005102
          the board that blinks on/off is m008423J LGEEBU60850003
          pictures atached.
          thanx
          • R_J
            • 9535
            I checked on SJ site and I don't think the boards are interchangeable
            LGEEBU61005102 used in 32LD350-UB.CUSWLH
            LGEEBU60850003 used in 32LD350-UB.CUSDLH
            Looks like the panels have different manufacture
            I found this listing on another site:
            Here are what to watch in model code-to understand manufacturer of panel
            XXLDXXX-XX XXXWXXX - LGD panel
            XXLDXXX-XX XXXDXXX - AUO panel (Acer Unipac Optronics)
            XXLDXXX-XX XXXMXXX - Sharp panel
            XXLDXXX-XX XXXCXXX - ? TN
            XXLDXXX-XX XXXGXXX - ? TN
            XXLDXXX-XX XXXRXXX - ? TN
            XXLEXXXX-XX XXXWXXX - LGD panel
            XXLEXXXX-XX XXXDXXX - AUO panel
            XXLEXXXX-XX XXXMXXX - Sharp panel
            • techietech2
              "OLD EX TV TECH
              • Jun 2013
              • 31
              This sounds right, I think I will just sell the boards on flebay and be done with this project.
              thanx for your help.
              • taipan
                • Sep 2013
                • slovenia
                on my PS board with PN: EAX61464001/8 IC500 has blown up so i can not see any mark on it. Could please anyone tell me what IC is this!
                Thanks in advance
                • Sorin.
                  • Nov 2017
                  • 4
                  Thanks in advance
                  hi i have the same problem on my ps and i found the ic500 is ICE3B0365J ,
                  let me know your rezults , hope this help.
                    • 12157
                    • U.S.
                    You might be waiting quite a while for a response, that last reply was over 4 years ago.
