Bose Lifestyle 650 remote malfunction
  • mpa2
    • May 2021
    • 15
    The push button for backlight is here
    • Diah
      • Feb 2013
      • 6557
      i think the issue at main unit transmitter didn't send sync feed back to RC so display didn't show any sign.. and it go to sleep look like it turned on with out any main unit closed to it
      any other RC under hand?
      • mpa2
        • May 2021
        • 15
        I would still expect some output on the display. The RC behaves erratic, thus I asked about a known working firmware dump for testing.
        I don't have another original remote, but with my harmony elite I can control the main unit without a problem.
        • Diah
          • Feb 2013
          • 6557
          yours harmony elite with out screen to sync feed back !! so how you put this in compare.... or i am wrong ?
          • mpa2
            • May 2021
            • 15
            Yes, harmony remote doesn't have a feedback.
            I monitored today the activity on the spi interface between the transceiver and the mcu. Sometimes you can see some activity after a key press, sometimes not.
            Could not find a system behind it.
            I'll try to find another remote for testing.
            • mpa2
              • May 2021
              • 15
              Well, I've found another remote, which worked without any issue. So no problem on the receiver side.
              I then reprogrammed the nvram of the broken one with the dump from the new one - now my friend has two functional remotes. The first thought is often the right one
              • hzwg88
                • Jul 2023
                Can you provide a nvram? Thank you
                • mpa2
                  • May 2021
                  • 15
                  Here you are!
                  • hzwg88
                    • Jul 2023
                    very thankful
                    • FALKLAN
                      Mercedes-Benz W163 Bose Audio System
                      by FALKLAN
                      Howdy everyone!
                      I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                      On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                      12-07-2023, 11:22 PM
                    • cstout
                      DeLonghi AC Remote only accepts 3V
                      by cstout
                      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                      I can't find any schematics...
                      06-03-2024, 03:53 PM
                    • Mc_Millian
                      Toshiba 50lf711u20 fire tv remote not pairing
                      by Mc_Millian
                      I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                      The Tv model number is: 50lf711u20 Rev B.
                      I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                      I've tried 3 different remotes which should be fully compatible with this TV.
                      Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                      The power button, along with the volume,back,select, and directional...
                      04-07-2022, 12:15 PM
                    • edugimeno
                      HiSense 55A7500F won't obbey to remote after power on
                      by edugimeno
                      Hi! I have this TV set that does the following:
                      1) I press the red power button on the remote
                      2) The TV turns on normally
                      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                      Then after it's off, it would again accept the TURN ON from the remote and same again
                      BUT:
                      -The remote does show the correct IR beam while observed thru a phone camera
                      -The TV works fine while using the MiRemote...
                      03-14-2023, 11:22 AM
                    • rustinjust
                      Please help, where can I get a remote for my subwoofer?
                      by rustinjust
                      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                      Is there...
                      10-28-2023, 03:43 AM
