Rca l32hd31yx13
  • dcapper
    • Dec 2013
    • 496
    Rca l32hd31yx13
    Acquired this tv the other day. Why I took it, I have no idea. Anyways I thought it was the main board. Payless Components sent me one and I installed it but removed it right away when I realized it was modded and missing parts. I sent it back. But it did the same thing my mainboard did. I can turn the tv on and off with the remote or panel but I get no pic or no sound. I am getting proper voltage to the inverter and to the mainboard. I still think it could be the mainboard but I don't want to sink any major cash into this thing.
    I just lifted the panel a little to take the pics. I can unhook it all to take better pics if needed.
    • 30985
    Re: Rca l32hd31yx13
    a much better pic of the board would help.
    i presume the backlight works.
    maybe you are missing he 12v line.
    the amps and panel are usualy 12v
    • dcapper
      • Dec 2013
      • 496
      Re: Rca l32hd31yx13
      I'll tear it apart tomorrow. Real dumb setup. Have to disconnect the tcon to open it up.
        • 30985
        Re: Rca l32hd31yx13
        lol
        i have a UMC (technika/tesco) pos here that has everything on the rear - other than the panel & controls.
        you have to split it about 6inches,
        then put your arm in and unplug the panel, the button-board and the backlights.
        only then can you take the back off fully!!!
        • dcapper
          • Dec 2013
          • 496
          Re: Rca l32hd31yx13
          Here is some pics from the power supply, mainboard, and inverter. I am getting 24v at the inverter.
            • 30985
            Re: Rca l32hd31yx13
            you need to power-up the psu& mainboard & meter the voltages on the connectors between the psu & mainboard to see if your getting 5&12v
            and then look at the mainboard voltage regulators - see if they all have outputs.
            • dcapper
              • Dec 2013
              • 496
              Re: Rca l32hd31yx13
              Metered all my points. All reading voltages. I removed my inverter board and metered where it goes to the panel and there is no voltage or before the steup transformers. I have the 24v coming in but dies somewhere on the board. Getting a short across a diode but I tested it out of circuit and it's fine. Tested all the diodes and transistors so far and no fault found.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                Re: Rca l32hd31yx13
                Check for something shorted in parallel?
                -David VanHorn
                • dcapper
                  • Dec 2013
                  • 496
                  Re: Rca l32hd31yx13
                  I think cause there is a schottky transistor by it, it might show the short. I'll take a good pic of the area after work.
                  • Mirenia
                    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                    by Mirenia
                    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                    03-30-2025, 06:47 AM
                  • orcic
                    MASTER TL240 and new mainboard LW36BKC01
                    by orcic
                    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                    Now I have some doubts about how to connect the new mainboard to the old power supply.
                    First of...
                    05-12-2023, 08:10 AM
                  • Devonavar
                    Vizio M43-C1 - How closely do I need to match the mainboard number?
                    by Devonavar
                    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                    So, I've ruled out the PSU for now.
                    The reboot loop...
                    08-14-2022, 08:46 PM
                  • Malva
                    Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                    by Malva
                    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                    Mainboard model: EAX65684604
                    PCB marking: EBT62954607
                    SPI chip: Winbond W25X20CLNIG Problem description:
                    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                    • I bought another
                    06-25-2025, 02:07 PM
                  • l0lhaxz1
                    QN65QN90A - Mainboard MLCC failed - now bootloop
                    by l0lhaxz1
                    Hi
                    I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                    Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                    Came to learn after a bit more research...
                    02-06-2023, 08:59 AM
