MAXENT MX26X3 L2614XW02L no standby light, no power on
    Re: MAXENT MX26X3 L2614XW02L no standby light, no power on
    Typical*1117-18 = 1.8V Fixed regulator, 1117-33 = 3.3V Fixed regulator. Adjustable will have resistor network on pin 1 and pin 2 and circuit ground, the voltage between pin 1 and pin2 of Adjustable should always show 1.25V if it is good.
    Read more here: https://www.badcaps.net/forum/showth...999#post300999
    • triplefour
      • May 2014
      • 1747
      ok thanks for the tips. ill check it out more and post my findings soon
      Don't fear the repair...
      • triplefour
        • May 2014
        • 1747
        of all these voltage regulators only
        the 2 LD1117's have 1.24v between pin1 and pin2
        the 84-33 0502AL has 1.3v between 1 and 2
        the 84-33 0515CL has 1.28v between 1 and 2
        the rest have voltages nowhere near 1.25
        is 1.3v close enough to 1.25 to call that an adjustable regulator and declare it good, or is it some other fixed regulator?
        are there only the two types? fixed and adjustable?
        adjustable is easier to test because its behavior relative to 1.25v can be tested
        but to test if a fixed regulator is good, is the only way thru knowing its datasheet?
        • triplefour
          • May 2014
          • 1747
          and i just cant find datasheets for these chips!
          "1084-33 0515cl datasheet" in google produces ZERO hits.
            The 1.25V ref for the Adjustable regulator is pretty tight around 2% tolerance.
            Can you take the reading of all 3 pins of all the regulators
            and report the reading as shown in the format in the link so I can verify all the readings for sure?
            Looking at it wit big tab up, the left pin is 1, tab is 2 right pin is 3.
            Close up pictures of these 2 also so I can see how they are connected.
            • triplefour
              • May 2014
              • 1747
              ok so i may have found the datasheet for this chip by typing in only "1084-33"
              looking at
              it seems to say this is a 3.3v fixed regulator?
              testing each of the pins though, i have 0, 1.29, 2.2
              weird when i made the measurements earlier in the picture i wrote it down as 0, 1.31, 2.13
              either way those numbers dont line up with 3.3v .... so is this my problem, or am i reading the wrong datasheet? how can i ever be sure?
                OK, I went back and look at the Voltage readings you had posted:
                IC701 (ADJ) 3.33V out, OK. Vin 5V.
                IC702 (ADJ) 2.5V out, OK. Vin 5V
                ICV8 (Fixed 9V) bad, due to low input voltage on pin 1, it should have 12VDC on pin1. Vin only 4.66V, too low.
                IC704 (ADJ) bad due to low input voltage. Vin is only 2.13V, too low.
                IC706 (Fixed 3.3V) bad due to low input voltage. Vin is 2.13V, too low.
                IC708 (Fixed 1.8V) bad due to low input voltage. Vin is only 1.31V, too low.
                IC710 (Fixed 1.8V) bad due to low input voltage. Vin is only 1.31V, too low.
                IC712 (ADJ) bad due to low input voltage. Vin is only 1.31V, too low.
                IC713 (Fixed 3.3V) bad due to low input voltage. Vin is only 2.13V, too low.
                As you can see, 3 of the regulators are fed by the same voltage source of only 1.31V, other 3 are also fed by the same voltage source of only 2.13V.
                Typical drop out voltage is about 1.4~1.5V (some can be a little lower, need to look at the spec), it means that for the regulator to regulate the output voltage, the input voltage must be at least 1.4V higher than the desired output.
                For example, for the 1.8V fixed output regulator, the input feeding the input pin must be at least = 1.4V +1.8V = 3.2V
                  OK, I look at my spare board and now I remember I try to fix this exact model before, it is commonly known problem with the main board due to poor solder on the BGA for the video processor, you can press on the heatsink then the picture will clear up. If you Google for this model, you will see.
                  Anyway, I kept the power supply board, if you look at the bottom side, it will have the voltage labels for the connectors.
                  CN504:
                  PIN1, 2 = +5VS (5VSTBY)
                  PIN 3, 3 = Ground
                  PIN 5 = ENABLE (PS_ON)
                  CN505: This one is not used on my board.
                  PIN 1, 2, 3 = +5V swithced (turns on when PS_ON is applied)
                  PIN 4, 5, 6 = Ground
                  CN503:
                  PIN 1, 2, 3 = +12V swithced (turns on when PS_ON is applied)
                  CN501:
                  PIN 1, 2, 3, 4 = +24V swithced (turns on when PS_ON is applied)
                  PIN 5, 6, 7, 8 = Ground
                  CN506:
                  PIN 1, 2 = +12V swithced (turns on when PS_ON is applied)
                  PIN 3, 4 = Ground
                  CN507:
                  PIN 1 = +5V swithced (turns on when PS_ON is applied)
                  PIN 2 = Ground
                  PIN 3 = +12V swithced (turns on when PS_ON is applied)
                  CN502:
                  PIN 1, 2 = +5V swithced (turns on when PS_ON is applied)
                  PIN 2, 3, 4 = Ground
                  PIN 6, 7 = +5V swithced (turns on when PS_ON is applied)
                  So check the ENABLE PIN to see if it toggle when power switch is toggled.
                  • triplefour
                    • May 2014
                    • 1747
                    thanks for all that info...i dont see how pressing on the vga heatsink could help since the standby power light doesnt even come on but i went ahead and tried that anyway with no effect...
                    in cn504 there are only 3 pins that have wires coming from them
                    pin 1, 3, and 5
                    they are 0, 0, and 5.06
                    none of these pins change voltage when power button is pressed.
                    • triplefour
                      • May 2014
                      • 1747
                      i think i had my pins reveresed but u get the idea...pin 1 has 5v, pin 3 is ground, and pin 5 should change when power button is pressed... what volts should it have? it just says PS_ON
                        Pressing on that heatsink has to do with pictures problem, not what we dealing with right now. You may find that out after we fix what is wrong and get the TV to turn on to see the pictures.
                          CN504 pin 5 (ENABLE), it should toggle between <1 (OFF) and >2VDC (ON).
                            It is 11, so I am going to bed, will try again tomorrow, night.
                            • triplefour
                              • May 2014
                              • 1747
                              i havent taken the power supply board off, but on the front side i can see a little white arrow pointing towards a pin...does the white arrow point to pin1?
                              • triplefour
                                • May 2014
                                • 1747
                                oh ok well thanks and ill keep trying...hopefully figure this out tomorrow then
                                • triplefour
                                  • May 2014
                                  • 1747
                                  i did notice that when i measure the voltage on CN6 Pin1 it drops from 4.98 to 3.6 when i push down the power button. when i release the power button it goes back to 4.98
                                  none of the other pins on CN6 do this.
                                  CN6 is where the button board connects to the mainboard. so i imagine it gets a signal via that voltage drop and then is supposed to tell CN401 to send the PS_ON signal to CN504 on the power supply.... but neither CN401 or CN504 do any changing of volts on any pins when the power button is depressed....
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    i see some...corrosion? idk even what to call it but the solder looks cloudy on the VGA connectors... what is that and should i try to clean it up?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      is there some way i can "trick" the power supply into turning on?
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        like if i jump one of the 2.13v lines to the PS_ON pin?
                                        • triplefour
                                          • May 2014
                                          • 1747
                                          im not gonna try anything sketchy tonight ill wait till tomorrow to get some professional opinions
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
