MAXENT MX26X3 L2614XW02L no standby light, no power on
  • triplefour
    • May 2014
    • 1747
    Re: MAXENT MX26X3 L2614XW02L no standby light, no power on
    ugh...now i cant get it to display normal even for a moment...
    heres what im getting on screen:
    please advise!
    Don't fear the repair...
      Well, that shows the same display as the one I did not fix, I was able to push on the heatsink to make the problem comes on goes, that is what I found on mine. I did not the hot air work station at that time to experiment with.
      • triplefour
        • May 2014
        • 1747
        yeah pressing on my heatsink does nothing...how hard are we talking about pressing here?
        • triplefour
          • May 2014
          • 1747
          oh nice...now pressing on the heatsink does work. ok so that is totally the problem, not overheating. but i dont have a reflow station... is there any acceptable "poor man's way" ?
          • triplefour
            • May 2014
            • 1747
            pressing on the chip only barely works and i think its getting worse from it...when i can get a clear picture theres still a little "snow" dang i have 2 motherboards with different problems.... if only i could combine them somehow then i would have a working motherboard!
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              many people have had success with a hot air gun, its not recommended as it is VERY easy to popcorn the chip. you would need some very thin flux as well. preheat in the oven then hit it with the hot air, but not for long.
              Liberating magic smoke one part at a time
              • triplefour
                • May 2014
                • 1747
                are u saying to put the whole board in the oven? at what degrees? and for how long?
                and what is "thin flux" ? i have some really old can of soldering paste flux .... is that the same?
                oh yeah and for now i solved the problem by wedging a wine cork and some tape inbetween the heatsink and the metal cover over the motherboard. it took a few tries to get the pressure just right but its been working for over an hour now with no problems. i have a feeling this will only work for so long though and i have to be careful not to move the TV...
                • Caleb
                  Smokin IC's
                  • Feb 2013
                  • 645
                  paste flux wont work, it has to be thin enough to go under the chip when heated, something like cs or kingbo, yes the whole board needs to be warmed up so you dont shock the chip. if it goes over temp it will never work again. Im not sure if you have a meter with temp sensors but that would be helpful in getting the chip to reflow without killing it. Or it might be just the excuse you need to buy a hot air station.
                  • triplefour
                    • May 2014
                    • 1747
                    yeah idk... hot air station is something im not going to be afford until i fix and sell a bunch of TV's ... the guy at the recycle place i can buy TV's from for 20 bux each has a hot air station though. he said he will charge me 40$ a chip to reflow things... might be worth it in some cases.... for now the TV is working fine with the cork in it...so maybe ill have him reflow it if and when that no longer works...then i would have spent 70 bux for a tv that i probably could have bought off someone on craigslist for 50!
                    • triplefour
                      • May 2014
                      • 1747
                      i guess what im saying is im going to stick to fixing only big TV's that i can get a return on my investment with...or small TV's if they are easy to fix and i get them for free.
                      • triplefour
                        • May 2014
                        • 1747
                        i guess i wouldnt mind trying the hot air gun and flux thing though if that could actually work. maybe ill try that myself before i take it to him... seeing that i have 2 of these chips now and im assuming the problem on the original mainboard was not the chip.
                        • Caleb
                          Smokin IC's
                          • Feb 2013
                          • 645
                          just be advised if you overheat the chip you will have to buy a new main board. You can get a cheap hot air station for about 100$, probably wont last forever but at 40$ a reflow it wouldnt take long to recover your out of pocket money
                          • triplefour
                            • May 2014
                            • 1747
                            yeah the guy i was talking about said he has a 5000 dollar reflow station...
                            wonder if he recovered that!
                            • triplefour
                              • May 2014
                              • 1747
                              wait so why does ruining the chip automatically ruin the motherboard too?
                                Try to find that replacement IC, then you will see why.
                                • triplefour
                                  • May 2014
                                  • 1747
                                  i dont really understand... what replacement IC? well anyway the cork finally gave out... i can push really hard on the chip to get it almost working again but it wont stay and its too much pressure. so the TV is down again...and im out 30 bux for the motherboard unless i can reflow it. but i dont have 100 bux for a reflow machine...i might be able to cough up 20 for a heat gun but will a 20 dollar heat gun do the trick? jeez...id really like to be able to actually diagnose and fix the problem on the original board... seems like it might be easier than reflowing a chip...but we got stuck and if budm doesnt know where to go next on that, then how would i figure it out?
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    http://www.ebay.com/itm/2-in-1-SMD-S...item4d1f2519fc
                                    should i buy this??
                                    • Caleb
                                      Smokin IC's
                                      • Feb 2013
                                      • 645
                                      What Budm is saying is that if you kill the main ic you won't be able to buy a replacement ic, instead you will end up buying a new main board anyway. The 852 got OK reviews by several people just be aware the core heater for the hot air isn't very durable. Probably a good idea to have an extra on hand. I think you might be best served by having your friend reflow it for you. The hot air station will require some practice as well before you dig into a chip you want to save.
                                        Thanks Caleb for the explanation on what I am trying to say.
                                        • Caleb
                                          Smokin IC's
                                          • Feb 2013
                                          • 645
                                          No problem, trying to save your time for troubleshooting the difficult ones
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
