Samsung UE48J6200K - No image but sound
  • Diah
    • Feb 2013
    • 6361
    Originally posted by Francesc V.
    This testing I have it pending. I need my wife not to be at home as the test requires "some space". :-)
    I'll let you know the outcome during the weekend.
    Thanks Diah for this suggestion.
    i do understand..... THX GOD i am again alone..LOL
    • lotas
      • Jan 2016
      • 4576
      • Russia
      Originally posted by Diah
      LOL.... lotas T-CON never being Voltage or currents,,, so what are all these muscle training you are showing here... LOL.... T-CON must an Panel connected... and must too the 12V VCC from it own PSU to match Freq. .... this is MUST if one want to handle T-CON in case he didn't have in hand Oscilloscope ... end of muscle training show.
      Who told you this, you can easily run this t-con on the table, with a jumper installed and by applying 12v to it, it should produce voltage to power the panel, and when you repair the T-con, you always take the original power supply from the TV, which should I check t-con?
      • Diah
        • Feb 2013
        • 6361
        i don't know where you read this but its impossible... forget it...
        to switch low V. you need P+ P- signal feed to each channel at T-con and this supplied from external which it have own socket.... don't listen to web crazy they did no one can only the manufacture of the LCD
        if you do it and you said yes i did i will believe you 0.1%
        • lotas
          • Jan 2016
          • 4576
          • Russia
          And we will ask Francesc V. whether it turned out to launch t-con or not.
          • Diah
            • Feb 2013
            • 6361
            deal... your sign will be 3 LED on T-con turn on.... sure they are but are this tell you the panel rubbish
            • lotas
              • Jan 2016
              • 4576
              • Russia
              #26
              Yes, first we will check the t-con, after we make sure that the output voltages are normal, we will install the t-con with the same jumper in the TV and connect one cable at a time to the panel and determine which half of the panel is not working.
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                #27
                Yeah!!! This jumper on RM15 made my day. I have had the T-CON working on my desk with the 3 leds on (BIG THANKS TO LOTAS). I have checked the voltages marked on the PCB (1.2, 1.8 & 2.5V checkpoints).
                Now that I have installed back in the TV, I am testing both ribbons without no final conclusions.
                - LED2 switches off after some seconds if both ribbons are connected.
                - LED2 keeps switched on if 1 ribbon is connected.............doesn't matter which one. I am testing rounds of 2 minutes if something weird happens.
                Update
                When left ribbon is connected, other part of screen remains black.
                When right ribbon is connected, other part of screen remains white.
                Also, as long as it was about minutes and minutes of testing, I've left TV unattended and only when left ribbon has been connected, 2 times I've found the TV switched off (I am marking in the picture as possible issue in this part of the panel)
                Let me know if you want me to test some additional voltages from the T-CON. Or everything suggests that is something wrong in that section of the panel.
                Regards,
                Francesc.
                • Diah
                  • Feb 2013
                  • 6361
                  from T-CON Photo RM13 are the bypass fault. to let T-com don't cut off GPU signal
                  • lotas
                    • Jan 2016
                    • 4576
                    • Russia
                    #29
                    Now it is not known whether your T-con is working or is already malfunctioning after your experiments (installing without knowing what jumpers, power supply and grounding of control points...), if the LED goes out, it is not the t-con protection that is triggered, disconnect the cables from t-con going to the panel and first check with a multimeter if there is short or low resistance on the ceramic capacitors on the buffer strips of the panel..
                    • lotas
                      • Jan 2016
                      • 4576
                      • Russia
                      #30
                      What kind of RM13? And how does it work around the defect?
                      • Diah
                        • Feb 2013
                        • 6361
                        from his last test.,, have one side white and other black. the same to other side which its black become white... so there are cut off of GPU signal ( Image)..
                        as i wrote before he need to disconnect the LVDS and keep your by pass in place and feed the T-CON 12V VCC direct from PSU to let the T-con being independed and the SPI could turn on the screen in pattern.
                        • lotas
                          • Jan 2016
                          • 4576
                          • Russia
                          #32
                          And also, carefully inspect the contact pads on the cables; over time, they dry out and when removed and installed, they break, move, and these lamellas on the cable short circuit each other.
                          • Francesc V.
                            Tempus fugit
                            • Nov 2022
                            • 231
                            • Catalonia
                            #33
                            Ok..........I had time to test your suggestions.
                            First of all I took some time to measure all components from the left buffer strips PCB. Nothing seems shorted or with low resistance. Important to mention that when I was measuring all these components with the strip disconnected from TCon, I was measuring "no ground" from one side of the capacitors, whereas, when connected..........one side from capacitors was pointing to ground and other had several K ohms.
                            Second test I performed "finally" was to disconnect Tcon from Mainboard and inject 12V. In parallel, TV was switched on to have backlight. The result has been a nice blank screen. Not sure if you where expecting a whole white screen there.
                            Regards,
                            Francesc.
                            • Diah
                              • Feb 2013
                              • 6361
                              Regards,
                              Francesc.
                              remove yours by pass RM15 and do it again as you explained
                              Note you can do it also in half screen a time
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4316
                                • Italy - Milan
                                #35
                                To me is not clear the post 19, the status of led 3, if present an image.. etc..
                                • Francesc V.
                                  Tempus fugit
                                  • Nov 2022
                                  • 231
                                  • Catalonia
                                  #36
                                  Yes, by unblocking the TCON I have been able to see picture and point the issue on left side of the panel (theoretically).
                                  Right now, TV is working for an hour and I have done "anything" .
                                  - Removing ribbons and clean them with isopropyl alcohol.
                                  - Removing the jumper RM15.
                                  - Playing with tape on the left panel ribbon with no success. Image was crap in all tests, but at least there was image :-)
                                  Tired of no success with tape, I've removed the tape and installed back the ribbon.
                                  Clear picture and sound for quite a long time...........it will not last very long, I know.
                                  I will continue with the test suggested by Diah.......because maybe, and just maybe it's not the T-CON neither the panel. Saying this because during testing, the image freeze (a frame) was kept in the background in the meantime the realtime picture was playing (not sure if you understand what I mean).
                                  Regards,
                                  Francesc.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4316
                                    • Italy - Milan
                                    #37
                                    First things i want to say, right to be clear, the led 3 is for the presence of panel supply voltages, when led 2 is for tcon circuitry supply present, the first to be executive is the pmic, then it is energized the main chip, and last the panel, since some time the panel has flaws or it is right the tcon unable to drive it well (and this is the main point , se next) it happens that panel feed it is released, this is my point now, my recent findings tells that with no visual oxidation or shorted components on strip boards, the main goal for the protection circuitry is to unload the tcon supply part, that could suffer, and not to protect the panel, and my bet is that you have bad bga balls on the couple of ic on board, more than this, im wondering witch chip is the one under radiator, seems a memory, lcd tcon uses no big flash or ram, sounds strange.. has it FRC function in the same chip? High integration is typical of developing bga problems..
                                    you have not clarified about led3 on the tests..
                                    ​​​​​another point, by cheating the tcon feedback circuit, and disconnecting one side, you are unloading a certain amount the tcon, so led 2 and vcore stays on, but connecting both sides dcdc stages suffers and vcore is shut down
                                    • lotas
                                      • Jan 2016
                                      • 4576
                                      • Russia
                                      #38
                                      When you installed the jumper on RM15, did you have voltages at t-con approximately: VGH - (+27v), VGL - (-8v), VDD - (+3.3v), VDA - (+15v), VCOM - (+8v)?
                                      • Diah
                                        • Feb 2013
                                        • 6361
                                        T-CON are slave as well the Panel.... all what you are seeking after VGH/ VGL/VDD(VDA/VCOM will not present if there no GPU signal... that's all search after the source to make all of these present. as OP he did.
                                        • Diah
                                          • Feb 2013
                                          • 6361
                                          thought you did trick the t-con by RM15. which it trick also the MB to transfer raw data.. now the RAM on MB stick full so the frame will freeze... find the chance as it is on now to log in service menu and make hard reset to clear RAM / T-CON action
                                          • wolf1976
                                            samsung ue40d6100 has no backlight no sound and image
                                            by wolf1976
                                            hi to all
                                            on the above model of samsung i have the faults i have told already on the title
                                            iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                            any idea from someone what can i measure so i can find the problem ?
                                            the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                            11-17-2024, 01:02 PM
                                            09-07-2024, 05:50 AM
                                          • andrhouseolly
                                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                            by andrhouseolly
                                            Hi.
                                            I kindly ask you to help me solve the problem.
                                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                            The board turns on, there is no image.
                                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                                            When you press the power button, the button indicator lights up. The board works
                                            there is no image, there is no matrix initialization, there is no image on HDMI.
                                            When turned on, the fans do not spin, but when they warm up they start spinning.
                                            When you turn off the button, the fans spin up to full speed for a short...
                                            05-11-2024, 03:14 PM
                                          • Egidio85
                                            Samsung UE55F8000SZ Turns on and off immediately
                                            by Egidio85
                                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                            This defect happens continuously, hearing the classic click of the relay every time.
                                            Power supply board BN44-00636B
                                            disconnecting the mains and lamps from the power board always causes the same problem.
                                            Is it normal that without anything connected this power supply turns on and off cyclically?
                                            any suggestions on what to check?
                                            thanks in advance
                                            03-11-2025, 12:45 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
