PLASMA TV 42PA4520-TJ: Vs Short cicuited...
    I'm working on an LG PLASMA TVC (model: 42PA4520). Short cicuit because of faulty FETs. I can read the following on 2 of these:
    G7S313u
    I R 235P
    B3
    and
    G7S313U
    I R 236P
    B4
    They seem to be N-channel and P-channel respectively (or vice-versa).
    Could anyone help to identify these 2 FETs and/or find possible replacement parts for them? Which one is the N-channel? (or are they both the same?)
    thanks...
    Re: PLASMA TV 42PA4520-TJ: Vs Short cicuited...
    Not sure how you concluded 1 is N and the other P channel when they both have the same part number.
    IR = International Rectifier
    (G7S313U)PDP TRENCH IGBT TRANSISTOR IRG7S313UPbF BY INTERNATIONAL RECTIFIER.
    GOOGLE really does work sometimes.
    Is a 42PA4520 a US market TV?
      Many thanks for the reply...
      In fact the 2 components are designated on PC board as Q's not D's...This why I assumed they should be FET's.. Next to these I can see other similar (in shape) components labeled as D's: each one (when tested) indicates that it is: 2 diodes integtated in one package (the usual double-diode components used in Power Supplies OUTs of of LCD, Plasma...TVs)...
      So what do you think...?
      I guess I must figure out what their function is in the circuit...
      I don't have the schematic...
        Not sure iff I'd bother at component level. Plenty available in the US.
        http://www.ebay.com/itm/LG-42PA4500-...item3a7c6eb1ba
        http://www.ebay.com/itm/LG-42PA450C-...item3f34150e16
        http://www.ebay.com/itm/YDRVTP-PCB-E...item2ec07a1041
