PLASMA TV 42PA4520-TJ: Vs Short cicuited...
  • Ahakim
    • Apr 2013
    • 64
    I'm working on an LG PLASMA TVC (model: 42PA4520). Short cicuit because of faulty FETs. I can read the following on 2 of these:
    G7S313u
    I R 235P
    B3
    and
    G7S313U
    I R 236P
    B4
    They seem to be N-channel and P-channel respectively (or vice-versa).
    Could anyone help to identify these 2 FETs and/or find possible replacement parts for them? Which one is the N-channel? (or are they both the same?)
    thanks...
  • tw2005
    • Oct 2011
    • 6458
    Re: PLASMA TV 42PA4520-TJ: Vs Short cicuited...
    Not sure how you concluded 1 is N and the other P channel when they both have the same part number.
    IR = International Rectifier
    (G7S313U)PDP TRENCH IGBT TRANSISTOR IRG7S313UPbF BY INTERNATIONAL RECTIFIER.
    GOOGLE really does work sometimes.
    Is a 42PA4520 a US market TV?
    • Ahakim
      • Apr 2013
      • 64
      Many thanks for the reply...
      In fact the 2 components are designated on PC board as Q's not D's...This why I assumed they should be FET's.. Next to these I can see other similar (in shape) components labeled as D's: each one (when tested) indicates that it is: 2 diodes integtated in one package (the usual double-diode components used in Power Supplies OUTs of of LCD, Plasma...TVs)...
      So what do you think...?
      I guess I must figure out what their function is in the circuit...
      I don't have the schematic...
      • tw2005
        • Oct 2011
        • 6458
        Not sure iff I'd bother at component level. Plenty available in the US.
        http://www.ebay.com/itm/LG-42PA4500-...item3a7c6eb1ba
        http://www.ebay.com/itm/LG-42PA450C-...item3f34150e16
        http://www.ebay.com/itm/YDRVTP-PCB-E...item2ec07a1041
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
        • adelfr2009
          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
          by adelfr2009
          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
          09-28-2025, 10:21 PM
        • Victor Moreira Silva
          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
          by Victor Moreira Silva
          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
          Well, my decice specs are the following:
          Model: Acer Nitro 5 AN517-54-55T5
          CPU: Intel Core i5-11400H
          GPU: NVIDIA GeForce GTX 1650
          Motherboard: GH51G LA-L181P Rev:1c
          The symptom:
          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
          05-26-2025, 10:49 AM
        • aaronkatrini
          Help me find the short circuit on this WORKING Nvidia GTX1650
          by aaronkatrini
          Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
          Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
          04-18-2024, 03:15 PM
