Panasonic DMR-ES30V power issues
  • newgen2005
    • Sep 2024
    • 18
    Originally posted by lotas
    Yes, higher voltage (10, 16, 25v,...) is possible, but lower voltage is not possible.
    And most importantly, observe the polarity of the capacitor (-, +) when replacing with new ones.
    Thank you for confirming, just ordered some from AliExpress, and an ESR meter. I have removed 2 of the suspect capacitors. Sorry for the dumb question but the hole where the leg is soldered to the board has small section of brown is that because I have removed too much of the solder? I was worried I may have damaged the board!
    • lotas
      • Jan 2016
      • 4461
      • Russia
      I don’t see, and I can’t say anything, what you did there.
      • EazyBone
        • Jun 2023
        • 1305
        • United states
        Spray alcohol and wipe with a q tip. Probably will go away
        Using flux right?
        • newgen2005
          • Sep 2024
          • 18
          Not used flux as I didn’t have any.
          • EazyBone
            • Jun 2023
            • 1305
            • United states
            That's a big mistake. You must use flux. You burned that pretty good. As for fixable I don't know since I've never done that. Maybe someone else can tell ya
            ​​​​​​dont do anything else until you get it.
            • newgen2005
              • Sep 2024
              • 18
              Yes, I think I’ve messed up here. Hopefully I can do can do something with it.
              • Diah
                • Feb 2013
                • 6343
                this nothings to do just solder new one in place..
                BUT good to see the circuit.. don't use any caps as yours first questioned on 680uf 10V will work,,,so don't use over rate more than 10V and don't use any over or less 680uf
                • lotas
                  • Jan 2016
                  • 4461
                  • Russia
                  #28
                  It's not a big deal, you just overheated the pads and they peeled off, you need to add flux or use rosin, old boards used getinax (modern ones made of PCB) and they don't like overheating, clean them with a toothbrush moistened with isopropyl.
                  • newgen2005
                    • Sep 2024
                    • 18
                    Thank you, I will use flux next time. I have some on order.
                    The 2 caps I removed were 680uF 6.3v and 680uF 10v. I have ordered 680uF 10v as a replacement for the 6.3v as I couldn’t see any that were shipped by AliExpress.
                    • newgen2005
                      • Sep 2024
                      • 18
                      Cleaned but it looks a right mess! Lesson learnt! Hopefully I haven’t destroyed the board!
                      • lotas
                        • Jan 2016
                        • 4461
                        • Russia
                        #31
                        Carefully clean (remove the mask (varnish coating)) with the sharp tip of a scalpel, wipe with an ear stick moistened with alcohol and tin the area with solder...
                        • newgen2005
                          • Sep 2024
                          • 18
                          Appreciate your help, thank you. How about the other part of the board? (the one that looks the worst) Do I need to remove the mask?
                          Are the brown sections without the solder just the none conductive part of the board?, I think the pad was under the solder so nothing conductive left?
                          I need to understand how the board works.
                          • lotas
                            • Jan 2016
                            • 4461
                            • Russia
                            #33
                            Well, the same thing here, clean and tin...
                            • newgen2005
                              • Sep 2024
                              • 18
                              I have replaced both capacitors, the machine powers up and plays videos but the dvd player audio isn't working. When I dub from VHS to DVD no audio can be heard from the VHS, the disc does record the sound though as I finalized the disc and played in another player. Any ideas?
                              • Diah
                                • Feb 2013
                                • 6343
                                recording / copy Data are blind work.. playing / review are coding matter.. if the code not supported you can nothings do with it
                                • newgen2005
                                  • Sep 2024
                                  • 18
                                  I should of mentioned audio on the DVD doesn’t work at all, you can hear like a static noise.
                                  • HKS00
                                    Panasonic CF-20 Track pad issues
                                    by HKS00
                                    Hello Everyone,
                                    My name is Haris and, I am new to the forum. I would appreciate any help I can get.
                                    Little back story on me and the issues that we are dealing with...
                                    I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
                                    03-08-2023, 10:34 AM
                                  • SuperAman
                                    Corolla FM CD Cassette Player issues
                                    by SuperAman
                                    Hi guys got a Corolla factory cd cassette player that was giving a lot of issues. It's from 06 Corolla, my friend the same unit in his corolla and he has the same issues.
                                    1. Stereo restarts by itself (thought loose connection but does this on bumpy and non bumpy surfaces) ''ST'' letters would blink on off on the radio when this would happen.
                                    2. Audio cuts in and out randomly for a second or a few minutes at a time.
                                    3. Shows MTL ERROR (randomly or after turning it on) assuming to do with tape deck which actually plays.
                                    4. Shows ERROR 3 (randomly or after turning...
                                    07-18-2022, 01:18 PM
                                  • gre0013
                                    Panasonic TC-59R62 Overscan issues. How to adjust?
                                    by gre0013
                                    Hello. I need help opening the service menu on a Panasonic TC-59R62
                                    Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
                                    Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
                                    07-26-2024, 10:14 PM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                    11-20-2024, 08:52 PM
                                  • RooTV
                                    Panasonic TH-65AX800A PSU Issues?
                                    by RooTV
                                    Hi all
                                    I have a Panasonic TH-65AX800A that turns on for about 2 seconds and then turns itself off.
                                    I got it like this hoping it was just a bad cap and an easy fix.
                                    I have pulled the power board and cannot see any obvious capacitor damage.
                                    Is there any other likely causes? Anything else I should check for?
                                    The power board is
                                    TNPA5937 2P
                                    with an additional silver sticker saying
                                    A1318VAL
                                    TNPA5937DA
                                    V1434
                                    I have tracked down another power supply which has the markings
                                    TNPA5937 2P...
                                    04-19-2021, 02:39 AM
