samsung ln40c500 sound no picture
  • ddgwood
    • Mar 2014
    • 13
    Hi,I have this tv that when turns on and get a split second of snow then no pic.but sound continues, I have the back off and i can see that the backlights are on.any thoughts? could it be a bad panel? or hopefully something easier. thanks guys.
  • ALR
    • Nov 2012
    • 111
    Re: samsung ln40c500 sound no picture
    Could be a bad T-con. I just did one where it had steady backlight and had sound, was a failed chip on the T-Con board. I would say it's either that or a mainboard issue. The main gives the signal to the T-Con and the T-Con turns the picture on. Usually with my experience which isn't that much but some, it loses sound if it's the mainboard.
    • ddgwood
      • Mar 2014
      • 13
      I am having trouble locating a service manual for this.anybody know where i can find one?
      • ddgwood
        • Mar 2014
        • 13
        what can i check to determine if its tcon or main?
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          Look on the t con board. Most have a fuse labeled f1 and you can check for continuity and also the voltage on both sides of it. Also doesn't this tv have two ribbons going to the lcd panel cause its a 40in. You can also try disconnecting one ribbon cable at a time that goes to the panel and then turning on the set to see if half the screen starts working.
          • mmartell
            • Oct 2013
            • 3189
            Some tv's mute the pic when no signal on the input. Does the menu does not show up as well ?
            • ddgwood
              • Mar 2014
              • 13
              checked fuse,has 13v on both sides of it.disconnected one ribbon at a time with no pic at any time,the menu doesnt come up at all.I dont know if there is supposed to be more voltages present on tcon from main board or not
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                Did you take one ribbon out then turn the tv on and test it then turn tv off and swap ribbons then turn back on. Cause if you swap them with the tv on it will short most of the time. If you did do it correctly I would say you need a t con board.
                • ddgwood
                  • Mar 2014
                  • 13
                  i did power it off when removing ribbons,luckily.a tcon would be about the best solution
                  • ddgwood
                    • Mar 2014
                    • 13
                    is it a bad sign when shopjimmy has 165 tconn boards in stock?
                    • audiofreak19
                      • Apr 2013
                      • 556
                      • usa
                      If it powered off when you were doing the ribbons then you didn't test it correctly. You need to have the tv off and unplug one of the ribbons. Turn the tv on and see if you get a picture on half of the tv. Then turn the tv off and unplug the other ribbon and plug the ribbon you unplugged before back in. Then turn the tv on and see if you get a pict on half of the screen. If you unplug it while the tv is on it will short and the tv will shut off and you have to turn it off and back on to reset.
                      • ddgwood
                        • Mar 2014
                        • 13
                        yes i did it just like you say
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          Ah sorry I read your response wrong. I would try the t con if removing each of them did not chane the image on the tv.
                          • ddgwood
                            • Mar 2014
                            • 13
                            so i switch out the tcon board and now i have about a four inch band of up and down stipes.when i put the original t con in if has a black screen.any thoughts
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • jchang
                              Samsung UN70NU6900F no picture and no sound
                              by jchang
                              Hi all
                              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                              Symptom:
                              No picture no sound.
                              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                              No sound at all.
                              What I tried:
                              1. I tried unplugging the left or right ribbon...
                              01-09-2023, 06:28 PM
                            • Dodgethis
                              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                              by Dodgethis
                              Hello all,
                              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                              09-11-2024, 07:39 AM
