Black screen on Sony 65x90ch (65x900h from Costco)
Ok, so from what I gather the optical no longer is lit, does the indicator led on front of the tv light up at all when you try to turn the tv on or in standby?Comment
Nope. nothing anymore. Pretty sure the main board is a goner now. I must not have unplugged the bottom jumper to the power on when I hooked it back up. measurements around the emmc were lower than what I would have expected. so my first step now is to replace the main board before I can determine if anything additional is needed. I'm actually looking for the main board that went to the spare power supply. My records dont showing being sold but I can't find it now. 😕 Thanks to everyone for their help
I may just jump over to another tv i had sitting around for awhile and try to finally fix that. it's turns on and goes to the sony logo then turns off. Guessing that'll be a bad main board tooComment
Here's the thing, not sure how you did that first test with the jumpers but IF you had the cable from powerboard to motherboard UNPLUGGED as would be correct way, then you could not have damaged the mainboard at all, so were the boards connected during that jumper testing?Comment
Main board power cable was disconnected. When I plugged the cable back in after pulling the jumper pins I'm wondering if I had only pulled 3 out fully and thr the power on one was still halfway in (it's on the bottom of the cable connector). That'd be my best guess. It might have overvolted the main. From what I've read when the main doesn't turn on its often the emmc chipHere's the thing, not sure how you did that first test with the jumpers but IF you had the cable from powerboard to motherboard UNPLUGGED as would be correct way, then you could not have damaged the mainboard at all, so were the boards connected during that jumper testing?Comment
No, this was a rigged up jumper done with very thin wires. The wire mainly popped into thr very small space between the plastic clip and wire harness itself. Didn't use resistors either as I guess I should have. Hopefully I'll come across this other board.Comment
Well I don't recall or forgot so I'll throw the question to Diah or someone who has verified it, no guessing allowed, does the optical led light up when the eMMC is bad?Last edited by nomoresonys; 09-16-2024, 04:11 PM.Comment
Yeah I did end up selling the old board. Kinds wish I didn't now. Looking for them, there are a couple of different main board numbers for thr 65x900h/65x90ch. Is there really a difference between 100689651 and 100689521? (A5031793A / A5014255A / A5014266A)Comment
Thanks. I did. They all list A5014266A whereas the existing one is A5031793A. I looked that up and it's a main board for a x91j or x91cj model. It's the next model year. This tv was purchased from liquidation.com/secondipity. Those people screw up so much.Comment
Those oughta work, they claim theyre new, if you want to make extra sure, just ask them if it will work with your panel number and give them the number or your sticker on the mainboard, NOT the silkscreen number: https://www.ebay.com/sch/i.html?_fro...4255A&_sacat=0Last edited by nomoresonys; 09-16-2024, 06:35 PM.Comment
Guess I'll be ordering the correct board and hope that fixes the issue. I'll have to check the tcon to make sure that's correct too.
Anyway, while you're here that other tv (65x90k) turn on, boots to the Google splash screen then turns off with 4 blinks. 4 blinks is most likely the backlights, right?Comment
Its a sony see? go ahead and put sony 4 blinks in the search above, you'll get a ton of threads on it.Comment
thanks. yeah I saw those. those are the correct ones. I'm not using the sticker number because it's for a J model, not an H model. I'm surprised this tv was working with the wrong board installed. obviously it doesn't anymore, but for a short time it did. I can't believe they put the wrong board in and sold it.Those oughta work, they claim theyre new, if you want to make extra sure, just ask them if it will work with your panel number and give them the number or your sticker number on the mainboard, NOT the silkscreen number: https://www.ebay.com/sch/i.html?_fro...4255A&_sacat=0Comment
 I can. Not long ago we spent a few hours trying to figure out why a vizio wouldn't work before we noticed the mainboard was completely wrong. It can be tricky, like when someone finds a tv or is given one without knowing if anything was done or tried. Some will buy a mainboard not knowing they have different ones for same models, it doesn't work so they get rid of tv, next guy assumes that the mainboard is original buys the same one and it just doesnt work.
I have a 850e Sony that has a board for a 850f. The TV turns on still and once it gets to YouTube to play or something it crashes. The original owner said he replaced the board and it worked for a while and the same thing happened again. I also had this exact thing with a different TV, and I ordered the correct board to fix it. So you might have a wrong board in there.
BUT like we learn here, I also have a 65 Samsung that when I lookup the board it's listed as a 55 inch tv and ONLY for the 55 also.
Hopefully the version you need is cheaper.Comment
			by Adam RussI'm stuck on this tv. It has sound, and has backlight glow, but no picture. I've tried new power board, and new main board, but no change. Tried a new t con but still no change. I've updated the firmware after new parts with no change. Is it likely the panel is just dead of would it be lvds cables. I did take some shorter ones I had on hand and connected those between the main and t con just to see if I'd get a picture but no luck. I'm not sure what else there is to blame. Do screens just go out completely but remain with a backlight glow? The screen has been removed and used a backlight...
			by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
			by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
			by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
			by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM - Loading...
