Sony Bravia KDL-46EX640 no power
  • bullwinkle
    replied
    Re: Sony Bravia KDL-46EX640 no power
    This is the result if I put high values on brightness, contrast, etc.
  • bullwinkle
    replied
    @ holmzy: can you please point out what parameter do I have to check?
  • bullwinkle
    replied
    ok many thanks. will update once I have time.
  • holmzy
    replied
    looks like u got the right panel number, i think the model names does not matter since the panel is right. looking at the service menu i can see at least one setting that conflicts with yours. match it according to the manual. but honestly i think one of your cables to the t-con / mainboard might not be in properly. doesnt to clean and reconnect
  • bullwinkle
    replied
    As you can see the model name is KD556EX640 but my TV is KDL46EX640 and the Main Power registers 001. Any suggestions?
  • bullwinkle
    replied
    More infos regarding service menu:
  • bullwinkle
    replied
    additional pics added for more infos:
  • bullwinkle
    replied
    still no progress. need help
  • bullwinkle
    replied
    been busy lately but will accept suggestions. will update once i have time to check the mainboard again
  • holmzy
    replied
    also 1 firware update affects all these TV's
    KDL-32EX403 / EX500 / EX501 / EX503 / EX505 / EX508 / EX603 / EX605 / EX700 / EX701 / EX703 / EX705 / EX706 / EX707 / EX709 / EX710 / EX711 / EX713 / EX715 / EX716 / EX717 / EX719 / NX503
    KDL-37EX403 / EX500 / EX503 / EX505
    KDL-40EX403 / EX500 / EX501 / EX503 / EX505 / EX508 / EX603 / EX605 / EX700 / EX701 / EX703 / EX705 / EX706 / EX707 / EX708 / EX709 / EX710 / EX711 / EX713 / EX715 / EX716 / EX717 / EX718 / EX719 / HX700 / HX701 / HX703 / HX705 / NX503
    KDL-46EX403 / EX500 / EX501 / EX503 / EX505 / EX700 / EX701/ EX703 / EX705 / EX706 / EX707 / EX708 / EX709 / EX710 / EX711 / EX713 / EX715 / EX716 / EX717 / EX718 / EX719 / HX700 / HX703 / HX705
    KDL-52EX700 / EX703 / EX705
    KDL-55EX500 / EX503 / EX505 / EX710 / EX711 / EX713 / EX715
    KDL-60EX700 / EX703 / EX705
  • holmzy
    replied
    I have a 52ex703 and for the life me could not figure out how to change the model version. Im 100% certain it is possible on my tv as its the exact same board for 7 different size models and even the service manual states change to your panel type but does not show you how which I find very sneaky! somone must know how to do it or get into the hidden menu like on samsung tv's
  • bullwinkle
    replied
    Any suggestions?
  • bullwinkle
    replied
    I think my plan is bad. Sony website states you cannot revert to previous firmware version.
  • bullwinkle
    replied
    Well, I again visually checked the original mainboard and the one that I bought (it displays 55" not 46" in its current firmware version). Comparing the two visually I could say it is all same ie components, etc.
    My plan is since the mainboard I bought gave life to the TV except it is showing greenish display and I also bought a T-Con board and result is still the same. So, this mainboard I bought displays 55" instead of 46" in its firmware, is it OK if I flash it with a lower 46" firmware and then flash it with the latest 46" firmware?
    The firmware version of the mainboard that I bought is current but I cant reflash it again since it will display the version is current and no option to reflash except cancel option.
    Any suggestions? Please?
  • bullwinkle
    replied
    Update:
    Got the T-Con board. Same thing. No progress.
    Time to take a closer look at the original mainboard. Any suggestions/help is appreciated.
  • bullwinkle
    replied
    Originally posted by tibimakai
    I'm the other way around, I have a 46" board and 55" TV. Shopjimmy states, that it should be compatible.
    Thank you very much for the info. Will update soon.
  • tibimakai
    replied
  • tibimakai
    replied
  • bullwinkle
    replied
    Oh my , ok thanks for the info tom66.
    replied
    That can cause problems, Sony TVs are notoriously picky about the panel size requirement. You need to use 46" board.
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • repair-it
    SONY Bravia OLED XR-77A80J will not power on
    by repair-it
    SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
    I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
    01-24-2024, 10:15 PM
