Hitachi 32hk04u
  • anotherdude
    • Feb 2013
    • 488
    Hitachi 32hk04u
    just picked this up no standby light
    will upload pics soon
    check psu fuse?
  • anotherdude
    • Feb 2013
    • 488
    Re: Hitachi 32hk04u
    so obviously another vestel
    17pw25-4 psu with noticable damage from the off
      Re: Hitachi 32hk04u
      I've done a few of these (probably my 4th now); replace all secondary diodes and repair the primary (5 SMD parts and a couple through hole.) Quite an involved job. I have one sitting on my bench right now that isn't cooperating; not blowing fuses any more... but not working.
      • anotherdude
        • Feb 2013
        • 488
        Re: Hitachi 32hk04u
        thanks tom
        series of burnt smd parts on the backside, I don't suppose you have a part list handy seeing as you've done a few, save me a few hours
          Re: Hitachi 32hk04u
          When you fix this could you do me a favour and measure some voltages?
          http://www.ebay.co.uk/itm/17PW25-4-P...item4ad363fdc2
          plus ALL of the UF5402 diodes on secondary. They give you two in the kit but you must replace all of them for reliability.
          • anotherdude
            • Feb 2013
            • 488
            Re: Hitachi 32hk04u
            ye of course happy to help, is it not better to buy them individually?
            £12 for parts seems kinda pricy
              Re: Hitachi 32hk04u
              It comes out to £8 if you buy the parts individually but I think you have to get them from Farnell and the FAN7529 from eBay, Farnell has a £20 minimum order.
              This is a fairly expensive and time consuming repair, it takes me about an hour each time.
              • vinceroger69
                • Mar 2012
                • 6714
                Re: Hitachi 32hk04u
                these arnt bad there brand new? £4.00 postage
                http://www.espares.co.uk/product/es1...FaVZ2wodo7gA7g
                Last edited by vinceroger69; 04-29-2014, 03:03 PM. Reason: put in the wrong postage cost sorry now corrected
                  Re: Hitachi 32hk04u
                  That is a pretty good price, might consider it for mine. A freebie 32" hitachi, probably same model #...
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Re: Hitachi 32hk04u
                    never used them myself but reading that add does say new they seem cheaper than ebay used ones.
                      Re: Hitachi 32hk04u
                      Only thing to be aware of is there are some versions of 17PW25-4 that have a jumper fitted and others which don't; they are interchangeable if you remove or fit the jumper.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Re: Hitachi 32hk04u
                        thats good to know at that price cant go wrong imo.
                        • anotherdude
                          • Feb 2013
                          • 488
                          Re: Hitachi 32hk04u
                          tbh think i'm going to go for one of them, £12 in parts plus maybe a few hours changing them over
                          but can't seem to get £2 postage, £4 for me tv owes me £25 though, not sure atm
                          think that seems the better option and maybe stick the board on somewhere to clear £10 after postage hopefully
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Re: Hitachi 32hk04u
                            sorry my fault just re read postage costs you are right i was going of the lower price item its still not bad imo though.
                            • anotherdude
                              • Feb 2013
                              • 488
                              Re: Hitachi 32hk04u
                              just picked up a toshiba 32kv501b with a smashed screen for £10
                              looks very similar to this hitachi, not had a chance to open yet but from memory toshibas are vestels too correct?
                                Re: Hitachi 32hk04u
                                Newer ones are but I'm afraid that uses a 17PW26-4 which is NOT compatible (believe me I've tried, and failed, to mod one into another.) I got the 26-4 from a 32KV501.
                                • anotherdude
                                  • Feb 2013
                                  • 488
                                  Re: Hitachi 32hk04u
                                  are you sure tom, looking through google with the model number and power supply search i get hits all over the place for this PSU
                                  https://www.google.co.uk/search?q=32...en-GB:official
                                    Re: Hitachi 32hk04u
                                    It's possible they used different PSUs throughout the production run (yay for consistency) but I definitely got my 17PW26-4 from a 32KVxxxB.
                                    (Possibly a KV500 vs KV501... I don't have the TV anymore...)
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      Re: Hitachi 32hk04u
                                      just checked it, luckily enough a 17pw25-4
                                      has the rocker switch too, so no messing round yay
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Re: Hitachi 32hk04u
                                        for £10.00 thats a good buy aslong as its working? maybe the t con and mains good too for future projects too. theres always smashed screen ones being offered on freecycle etc if local i will collect them for the boards etc.
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • sotodefonk
                                          Help finding the correct model of a T-Con board on my Hitachi TV
                                          by sotodefonk
                                          Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                                          I opened the tv to access the board and took the shared pictures of the T-Con board.
                                          I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                                          I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                                          Inspecting...
                                          06-28-2024, 04:39 PM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
