Hitachi 32hk04u
    Re: Hitachi 32hk04u
    Toshiba 32BV701B has one, as does one Digihome 26" and a Hitachi L32HK04U in this case.
    • anotherdude
      • Feb 2013
      • 488
      • uk
      #42
      Re: Hitachi 32hk04u
      Originally posted by tom66
      Great, I've looked everywhere and no one has them. This one has been in the pile too long...
      I am sorry Tom, I just can't wait round these days
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        Re: Hitachi 32hk04u
        ok i will go through my emails and see if i have been offered one of these sets but i will defently keep a look out for one now.
        • gcp1975
          • Sep 2013
          • 7
          • united kingdom
          #44
          Re: Hitachi 32hk04u
          Check if your bad original PW25-4 has a little jumper fitted to the bottom of it near the main board power connector. IIRC it's S815. If it does copy that across to the other board. If it doesn't remove it.
          That jumper being in the wrong position will cause a flash of death.
          The caps have nothing to do with it.
          Hi all , i have just swapped a 17pw25-4 and having the similar flashing led ... i simply cannot find the jumper i need to remove !! any help would be greatly appreciated.. thanks in advance Gary
            Re: Hitachi 32hk04u
            Little surface mount thing, on the bottom of the power board near the output connector (goes to main board.)
            Post a pic of the bottom of your board and I will highlight it.
            • gcp1975
              • Sep 2013
              • 7
              • united kingdom
              #46
              Re: Hitachi 32hk04u
              hi Tom, thanks for that, but i can only see a s814
              • gcp1975
                • Sep 2013
                • 7
                • united kingdom
                #47
                Re: Hitachi 32hk04u
                So sorry , just re read the thread s814 is going to go !
                • gcp1975
                  • Sep 2013
                  • 7
                  • united kingdom
                  #48
                  Re: Hitachi 32hk04u
                  many thanks !! its working ... i bought a board on ebay, and it blew when i connected inverter board, so i got an other psu and a second hand inverter board and its all good , psu buzzing abit though !!Gary
                    Re: Hitachi 32hk04u
                    Normal for these PSUs to buzz... they are absolute rubbish....
                    • gcp1975
                      • Sep 2013
                      • 7
                      • united kingdom
                      #50
                      Re: Hitachi 32hk04u
                      assuming, that both the psu and inverter board were brand new, how long do you think it'll last ?
                        Re: Hitachi 32hk04u
                        Best measured in hours. Every single one that's failed on me has had between 2000 and 3000 hours of usage. I've seen four now with the same fault (blown primary FET due to shorted output diodes.)
                        If you watch TV for 4 hours per day (that's the national average) that's between 1.5~2 years of usage. Of course the parts are used, so they already have some of their life used up, so to speak, like installing already worn break pads on a car...
                        These truly are steaming piles of junk. The only real way to fix them is to mod a 17PW26-4 and install that. It's a much better power board (for a Vestel at least, it's not too badly designed) and it lasts much, much longer.
                        • gcp1975
                          • Sep 2013
                          • 7
                          • united kingdom
                          #52
                          Re: Hitachi 32hk04u
                          i have 2 of these boards, both with fried smd chip and other smd's are they any good for repair or should i keep the caps for future repairs ?
                            Re: Hitachi 32hk04u
                            Don't reuse capacitors from boards... especially not Vestel boards... look up voltage forming it essentially makes it a very bad idea to use capacitors from other boards unless you can be certain that they have been both exposed to the same voltage (i.e. if you use a 35V cap which has run at 24V for most of its life on a 30V circuit, the capacitor can be damaged and vent.)
                            Just keep them for the various smaller parts.
                            • massimomax
                              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                              by massimomax
                              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende piΓΉ,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                              spero che qualcuno puΓ² averlo per riprogrammare eprom. grazie
                              Post in English !!!
                              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                              02-28-2025, 07:27 AM
                            • dragometin
                              Hitachi 40HYC42
                              by dragometin
                              TV Model: Hitachi 40HYC42
                              Power Supply: 17IPS71
                              MainBoard: 17MB95M
                              Panel: VES400UNDS-2D-NO3
                              When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                              I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                              Is there any variants on 17IPS71 power supply's?
                              UART output pins 10 and 12 on scart connector:
                              Code:
                              12:24:04.595
                              08-08-2024, 05:53 AM
                            • sotodefonk
                              Help finding the correct model of a T-Con board on my Hitachi TV
                              by sotodefonk
                              Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                              I opened the tv to access the board and took the shared pictures of the T-Con board.
                              I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                              I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                              Inspecting...
                              06-28-2024, 04:39 PM
                            • dicky96
                              Hitachi V19B01922 Channel Tune problem
                              by dicky96
                              Hi Guys
                              I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                              He also has an LG TV, so three screens in the bar
                              I installed three Satlink ST-6503 DVB-T Modulators
                              This model https://www.aliexpress.com/item/32916553905.html
                              These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                              02-09-2023, 09:20 AM
                            • navagator
                              Hitachi Power Supply Unit Interchangeability
                              by navagator
                              I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                              Does anyone know if these 2 power supply boards are interchangeable?
                              Thanks.
                              01-08-2024, 07:53 PM
