Hey finally getting around to ordering me an "A" board for my tcp50g20. WOW not cheap! My board is a tnph0834 1a. I am finding lots of boards from different model numbers, say for example a TCP54G25. Mostly refurbished boards, no new ones. Will these work as long as the part number matches?
Panasonic "A" board replacement
Re: Panasonic "A" board replacement
No, you must use the 50", non-3D board. You should be able to use V20 or S20 for example, but not VT20 or GT25, or 54" board.
You also need to use the board with the right inputs - some have 2 HDMI, 3 HDMI, 4 HDMI, built in satellite, or VGA port, etc. That's important.Last edited by tom66; 04-28-2014, 09:21 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
http://www.ebay.com/itm/Panasonic-TC...item3cd8ae3fb3
You'd get away with the50g25, IC8502 has different firmware between the 2 but same panel and boards otherwise so probably some extra feature I am guessing.
The GT25 happens to be just a STD FHD but the board is a different number and wider so would not fit in your cradle. That's the model I used as a donor for my SC boards .
Considering what a SC board goes for now, $120 for a main is probably fair game.Last edited by tw2005; 04-28-2014, 10:18 AM.Comment
Let me check my parts shelve,it sounds familiar, I might have one. Give me an hour. I will inbox youProud owner of dozens of broken TV's and many,many,many boards.
Our website and passion:http://hollenhundshepherds.com/Comment
Darn, I only have a couple G10's,S30's and U50's. thought I had a G20 but guess not
hey everyone. me again. Tv worked fine for about four months, now I'm getting a 10 blink code. Wondering if I may have gotten a "weak board", or maybe I have a bad P board. Either way, I'm trying to decide weather to junk it or order a new board. Opinions?Comment
Hmm, I have a bad feeling it just blew a SC board. They can trigger SOS4 and 10 blink. Could check SC2 for short but might not be since you have 10 blink.
test q661 and see if shorted as that one seems to fail short .
You could disconnect sc2,ss11, p35 and the 3 white ribbons from the A board.
Turn tv on and see if it stays on, no picture. If so that would pass the PSU and A, SC would be prime suspect then I feel. If still 10 blink, probably A board.
Don't reconnect those power leads after shutdown, leave for 5mins so you do not spike the boards especially P35Comment
I am getting about 2M ohms across sc2. with the cables below disconnected, I get a solid power light for about 2 minutes, then I get 4 blinks. P board or more?
No, I have a vague recollection that happens , you're not meant to run it that long and I think I made that mistake too when I first started working on mine.
Use the manual to locate the P5V and P15v lines that enter sc20 in the schematic and measure the resistance to a gnd point on the sc. Disconnect SC20 or you'll be measuring the A board side as well.
Did you check q661 as I sugested?Comment
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
Assuming...7 Photos -
by boosti45i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... - Loading...
