Westinghouse LTV-37w2hd was working, now turns on and halts on W logo or Blue screen.
  • Shinju
    • Mar 2014
    • 1239
    Hey friends!
    I got this 37" Westinghouse for 5.00 out of the recycle pile at the local VV today.
    I got it home and plugged it and and it fired right up, I plugged in my HDMI bluray player and watched Avatar from start to finish on it. Was working great, had a great picture, sound ect.
    After the movie I decided to go into the menu I hit the menu button and it brought up the menu and then BAM the backlight went off but the audio was still going.
    I couldn't turn it off as it seems the buttons were locked out. I unplugged it and it came back on with a solid blue screen, again I couldn't turn it off via the button. After a few more times I finally got it to turn back on and show a picture but no audio and the buttons were not responding and now its just stuck doing the W logo or a blue screen.
    I searched here and didn't find much on this unit but could this be a bad mainboard or a corrupt firmware? I couldn't find any firmware updates for this unit.
    I can take it apart and get photos of the boards, these are a pain! lots to remove
    Sorry not much to go on here, I will try to tear into it tonight.
    Was crazy it was working great I was really impressed by it as I had it next to a 40" Sammy and it looked more natural.
    Thanks for reading
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Westinghouse LTV-37w2hd was working, now turns on and halts on W logo or Blue scr
    Yea just from what you have said it does sound like a main board. Since that controlled the turn on and sends the video signal and signal to turn backlight on and off. And beig stuck on the logo would should kinda like the EEPROM issues vizios have.
    • Shinju
      • Mar 2014
      • 1239
      Lame! If only I had a firmware update to try and push to see if it can be resolved.
      I am going to take it apart and see if the eprom is socketed like the newer gen one I took apart today for a friend. That one too has a bad mainboard as the PS is putting out the right voltage. It just sits dead with a Orange LED.
      Thanks for the reply, I might just get a new mainboard I only have 5 bucks invested and they seem to be pretty reasonably cheap.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        I would just try to get a new main board. Your probably not gonna find a EEPROM for that main board.
        • Shinju
          • Mar 2014
          • 1239
          So I ended up getting the entire guts to a 37hd for super cheap. The tv fired up and I was able to surf the menu and change inputs ect. I have not put a singnal to it yet.
          My quest is the original mainboard was power by ATI CPU the new one is not, is there going to be a difference in picture quality? Does anyone know of a place I can get a firmware update?
          I will report back when I get to see a signal work. Also I have a ton of extra parts for one of these minus the mainboard.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            If you can get a update it would be from the manufacturer website.
            • Shinju
              • Mar 2014
              • 1239
              I tried their website no dice, good news is the tv works the bad news is the HDMI port seems to be bad and doesn't work. I tried a Facotry reset with no luck. The funny thing is if I have a composite source and plug in the hdmi cord it switches to that input and says HDMI no signal detected, does this even if I select it manually or turn the tv off then back on.
              • Shinju
                • Mar 2014
                • 1239
                No audio on any input! Lol well shoot.
                • Shinju
                  • Mar 2014
                  • 1239
                  Hey friends.
                  I got another mainboard, this one is an ATI mainboard same as the original one. Again I have no HD, HDMI, no componate and no audio. I do however have standard AV with no audio.
                  I did the reset all, reset picture and reset audio. I am at a loss on what to do, there was these foil sticky stripes on the shell of the main/ps case that attached to the back if the panel and one smaller strip that attached on the part if the mainboard near the t-con connecter that stuck to the backside of the shell that housed both the ps and mainboard, do those strips need to be there? Are they more then just a noise/interference strips?
                  I cannot believe that 2/2 mainboards are DOA in the same manner, well almost the non ATI board all inputs worked (no audio) and the hdmi was dead.
                  Any suggestions on what to try for next?
                  • Shinju
                    • Mar 2014
                    • 1239
                    Another thing to note aswell, the auto signal sense is on and when I turn on a device it switches to that input and and after 2 seconds it says no signal and goes into stand by.
                    • ecking767
                      • Oct 2009
                      • 492
                      do you get sound on the TV input using an antenna?
                      • Shinju
                        • Mar 2014
                        • 1239
                        I don't have cable, but I can hook up a game system using rf.
                        • Shinju
                          • Mar 2014
                          • 1239
                          No audio using RF, I have an HD antenna I can try but I am not getting any audio with RF I don't think the hd antenna will change that but I will try
                          Thanks for the suggestion!
                          • mmartell
                            • Oct 2013
                            • 3189
                            Sounds like those MB's not compatible.
                            • Shinju
                              • Mar 2014
                              • 1239
                              I don't think it's that, I have the entire guts to another Westinghouse here and althought the mainboard and power supply are different revisions the harnesses all match up, even the t-con and it's cables match up.
                              I put in the non ATI board back in and I think I am just going to sell it as is and return the other ATI mainboard. The non ATI mainboard at least had all working connections besides HDMI.
                              • Shinju
                                • Mar 2014
                                • 1239
                                Oh and the speakers work, I ohm tested them and hooked them up to an external source.
                                • ecking767
                                  • Oct 2009
                                  • 492
                                  what about +12 volts from the power supply? did you check the power supply caps? post picture of the inside
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    I put it back together, I am not sure this is a power supply issue. The tv turns on with no hesitation. The messed up part was when I first got it it was working fine, HDMI And audio on all inputs, the second I hit the menu button to tinker with the picture settings is when the original mainboard took a shite!
                                    Oh well, it's just a Westinghouse it actually had a pretty nice picture and sound for a lower end panel.
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      I do however have another revision power supply from a donor LTV-37w2HD guess I can try that and see what happens.
                                      • ecking767
                                        • Oct 2009
                                        • 492
                                        do you have an multimeter and a soldering iron? Im sure you will need it, this is a older model TV and my first guess will be bad caps on your power supply.
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • taslan
                                          Surface 7 Pro wont boot, shows Logo and immediately turns off
                                          by taslan
                                          as stated in the title, my surface 7 pro wont boot anymore.
                                          When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                          I dont even have a chance to get into bios or boot from usb.
                                          While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                          I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                          Bought it directly from microsoft and used it now and then and only...
                                          01-16-2025, 01:25 AM
                                        • questore
                                          gigabyte BX-BT1900 BRIX Rev 1.2 blue led turns on but no start.
                                          by questore
                                          Hi Everyone,
                                          I have 5 of these BX-BT1900 and 2 of them are not stating after a proper shutdown.
                                          Symptoms:
                                          - Computer starts as soon as power adapter plugged in and blue light turn on on the power button. Fan spinning, but no picture
                                          - All power rails present and fine and CPU is slightly getting warm
                                          - Nothing else is getting hot (thermal camera shows no exceptional heat)
                                          - Tryed BIOS clean and reflash from here, but no luck. BUT someone suggested that I should try LPC clock temp fix.
                                          I have found the LPC connector according to this documentation:...
                                          01-05-2025, 08:13 AM
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
