Samsung UN46D6003SFXZA screen dark then bright
  • aasnowskate
    • 118
    • usa
    I have a Samsung 46in LED TV M# UN46D6003SFXZA. The screen goes from bright to dark and back and forth. The backlights do not seem to be dimming at all when you stand behind the TV. The voltages from the power supply to the backlight do not change when it goes dark. The picture kind of looks like it is flooded with red.
    Has anyone had this happen? I went into the servicer menu and reset the factory settings and this did not help. I am leaning toward the main board being the problem.
    I will post pics of the boards shortly.
  • aasnowskate
    • 118
    • usa
    Re: Samsung UN46D6003SFXZA screen dark then bright
    here are the pics of the boards and the difference between when the picture is bright and dark.
      Hard to tell - Can you see what a "black" image looks like on the panel to see if the backlights drop out.
        • 31055
        i think your losing some blue bits - maybe a bad buffer ram or bad soldering on the scaler chip.
        • aasnowskate
          • 118
          • usa
          I put the TV on channel 3, which is a blank or black screen and then after a few seconds it goes to a snowy picture. The screen is black and the backlights get really dim and when it goes to snow, the backlights light back up to full brightness.
          The backlights do not dim like this when there is a picture and the picture goes dark.
          • aasnowskate
            • 118
            • usa
            I am assuming that the buffer ram and scaler chip are on the main board?
              • 31055
              they are.
              scaler chips often get *very* hot and should have a heatsink stuck on them - but often they dont bother to save money!
                First I think check the backlights, but if they don't dim you can check the scaler from the service menu.
                Just put TV into standby and press Mute, 1, 8, 2 then power it on.
                Then access Control > Test Pattern
                there should be about 3 generators there which lets you narrow it down to T-con/Panel or main board.
                Personally with knowing how bad the early panel failures are on Samsung D-series TVs I'd be thinking panel :/ for your sake I hope not!
                • aasnowskate
                  • 118
                  • usa
                  I can not find a test pattern under the control in the service menu.
                    Can you show a picture of what you've got instead? I'm using what I did on a B-series LED as reference.
                    edit: page 3 bottom right, try that
                    • aasnowskate
                      • 118
                      • usa
                      here is the pic of the menu and then the next menu when control is selected.
                        See my edit.
                        • aasnowskate
                          • 118
                          • usa
                          I went through all the test patterns and they looked fine, but the screen was still darkening and brightening the same while going through the tests.
                            So you will need to check the backlight for us. Any BLACK test pattern? Turn all lights out. If the black level (the slight blue or grey glow from the panel) varies, then the backlights are causing your problem...
                            If not... it is the panel or T-con.
                            • aasnowskate
                              • 118
                              • usa
                              With the black test screen, the backlights do not vary at all. The test indicator display in the upper left corner of the screen brightens and darckens, but the screen and the backlights (when I stand behind the TV) do not vary at all.
                                Well, then, it is a crap-shoot between T-con and panel.
                                I would say panel has a fair chance, due to tab bond fault.
                                • aasnowskate
                                  • 118
                                  • usa
                                  After all the tests, I am thinking the same thing. I might play around with the tab bonds and see if I can make it act up by pressuring them, but this is the 3rd Samsung that has had a bad panel due to those tab bonds being on the bottom of the set.
                                  Thanks for the help. If I order the T con, I will post my findings.
                                  • aasnowskate
                                    • 118
                                    • usa
                                    I ordered the T con from ebay and it fixed the problem. Thanks again Tom66 for the help. I was thinking bad panel tab bonds, but when I pushed and lightly stressed them, the pic did not change. When I sprayed some freeze spray on the T con board, the pic would change. That helped me think it would be the T con. All fixed up now.
                                      That's nice to hear you got a solution in the end. I am surprised!
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Maybe next time it will be the panel. I wouldn't keep a D series.
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
                                        • bohaboha
                                          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                          by bohaboha
                                          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                          anyhow i couldn't t read anything else
                                          the backlight is on strong and the screen does not get dark or very dark but no pictures
                                          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                          01-02-2025, 08:04 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Topcat
                                          Samsung UN75RU7200FXZA - Right 1/3 Portion of Screen Dark
                                          by Topcat
                                          Set from 2019.....sad this is all they last anymore. Ok, obviously a backlight problem. From what I understand there are 3 strips in these, mounted vertically....one seems to be bad. The image is present behind the darkness, not a LVDS or TCON issue.
                                          This TV is a beast. I can't even manhandle it by myself, let alone try and lift the screen out to restrip it.....but I haven't even gotten this far yet....I can't seem to find strips for it.
                                          I found a set for the UN75RU7100FXZA but not the 7200.
                                          https://...
                                          05-29-2023, 08:33 PM
