Lg32ld490
  • sordids999
    • May 2013
    • 2149
    Re: Lg32ld490
    thanks
    • sordids999
      • May 2013
      • 2149
      Re: Lg32ld490
      i can access the LG hotel mode setup but not much options in there plus ive tried to downgrade the firmware via trying pressing 9 (7) times but still only volume but no picture
        Re: Lg32ld490
        You get audio from the connected sources?
        • sordids999
          • May 2013
          • 2149
          Re: Lg32ld490
          i tried the video on youtube where you connect the headphone wires to a IR from a remote then used the required wav files close up the the tv sensor which should in theory load up the 4 digit pin but nothing happened
            Re: Lg32ld490
            Try reversing the IR. Also, make sure to turn up PC/phone/ipod volume to maximum.
            • sordids999
              • May 2013
              • 2149
              #26
              Re: Lg32ld490
              tried that tom
                Re: Lg32ld490
                Hmm, not sure then, sorry.
                • sordids999
                  • May 2013
                  • 2149
                  #28
                  Re: Lg32ld490
                  yeah me too ill wait until a board becomes available thanks for your help
                  • sordids999
                    • May 2013
                    • 2149
                    #29
                    Re: Lg32ld490
                    ok tried again tonight via a smartphone using the IR sensor trick still nothing but watching the videos i think i need a picture but not sure about that,so is there anyway i could reset the EEPROM ive tried to downgrade to 3.15 which apparently you can then access the service menu but no files around
                      Re: Lg32ld490
                      You shouldn't need a picture. What code are you trying? Tried using IN-START from standby mode? Also, show us your set up - are you definitely using an IR LED... to confirm if the LED is working, point a digital camera at it, or look at it with your phone in the mirror, you should see a bright purple or white flash from it on a camera (invisible to the human eye.)
                        Re: Lg32ld490
                        I wish I had an LG here to try that trick with my Galaxy S2. I'll see if I can do it with another TV. Sold both LGs a week a go :/.
                        • sordids999
                          • May 2013
                          • 2149
                          #32
                          Re: Lg32ld490
                          im not sure if you can see but i copied a website to make this and im using the
                          serv-ok-ok.mp3 which i got from the lg site
                            Re: Lg32ld490
                            Try the camera trick to make sure the LED is producing a signal.
                            • sordids999
                              • May 2013
                              • 2149
                              #34
                              Re: Lg32ld490
                              not its not tom i tried the remote before i took it apart so i know the LED is working
                                Re: Lg32ld490
                                If the output of the phone is too low, the LED will not light. Or a wire could be broken in the cable.
                                Try using a laptop/desktop, output may be higher.
                                • sordids999
                                  • May 2013
                                  • 2149
                                  #36
                                  Re: Lg32ld490
                                  Well thats 3 LED ive used three sets of wires pc,phone,laptop still cant get the led to light up
                                    Re: Lg32ld490
                                    Cable is OK?
                                    Check camera against known working remote.
                                    • sordids999
                                      • May 2013
                                      • 2149
                                      #38
                                      Re: Lg32ld490
                                      Just typical games work on screen in menu and a movie loads up fine via usb but no scart,hdmi anything lol well no mainboards around so i guess its a dvd player for now
                                      • sordids999
                                        • May 2013
                                        • 2149
                                        #39
                                        Re: Lg32ld490
                                        yeah tom tested a remote with my s4 worked fine via camera
                                          Re: Lg32ld490
                                          Have you tried getting a hold of a URC3940? I keep one for TVs I don't get a remote for. They are £7 on eBay and will do almost any TV.
                                          http://www.ebay.co.uk/itm/ONE-FOR-AL...item1c33abf75a
                                          Plus they can apparently access the service menu... see here
                                          http://openlgtv.org.ru/wiki/index.ph..._menus_/_modes
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • reassor
                                            Sony kd70xf8305 very very slow android logo with sound
                                            by reassor
                                            Hi.
                                            Power is ok
                                            Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                            Should i force update? If so how?
                                            I did reset.
                                            Mainboard Looks pristine.
                                            Very wierd.
                                            10-30-2023, 05:59 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
