Lg32ld490
  • sordids999
    • May 2013
    • 2161
    Lg32ld490
    hello
    got this tv today i have sound but no picture but i still have the lg logo showing on the mainscreen
    any ideas ?
  • sordids999
    • May 2013
    • 2161
    Re: Lg32ld490
    just tested voltages all seem fine
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Re: Lg32ld490
      Any menu functions onscreen?
      Tried any other input sources?
      Any sound?
      TELEFIX
      • sordids999
        • May 2013
        • 2161
        Re: Lg32ld490
        The menu works when try via remote and the side buttons also tried the avi,scart but just sound with the LG cube showing on the screen
          Re: Lg32ld490
          LG No Signal cube? Are all inputs dead? What about Freeview/DTV?
          I have a friend with a smashed 32" like this, he might have a main board... I'll ask him if you're interested.
          • sordids999
            • May 2013
            • 2161
            Re: Lg32ld490
            Yes tom tried all hdmi connections and avi have not got a aerial to test only virgin box available,I'll appreciate it if you could ask your friend plus yes to the lg signal cube logo
              Re: Lg32ld490
              OK, do you have anything with SCART on it? Tried that?
              • sordids999
                • May 2013
                • 2161
                Re: Lg32ld490
                Scart also does not work tom
                  Re: Lg32ld490
                  OK, hold MENU on TV and MENU on remote. 10 seconds. Does service menu appear? Note: if code prompted try 0000, 3142 or 1234.
                  • sordids999
                    • May 2013
                    • 2161
                    Re: Lg32ld490
                    Is there a special way of doing this tried on the last lg I fixed can never even get into the part where u enter a code
                      Re: Lg32ld490
                      It sometimes requires a factory remote, depending on the model; someone on a forum said you can use a universal remote but didn't include any code.
                      • sordids999
                        • May 2013
                        • 2161
                        Re: Lg32ld490
                        I can use a USB connected to main board to play a movie on there and it's playing fine so this is strange
                          Re: Lg32ld490
                          I assume you've tried user menu reset...
                          • sordids999
                            • May 2013
                            • 2161
                            Re: Lg32ld490
                            Yeah done a reset in the menu u connect hdmi lead it says connecting then no signal it has built in games that work as well in the menu
                              Re: Lg32ld490
                              Really need to get into that menu but can't find anything on it - maybe try googling it a bit more as I only had a brief look, someone mentioned a One 4 All remote working.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Re: Lg32ld490
                                http://openlgtv.org.ru/wiki/index.ph...es#Procedure_3
                                • sordids999
                                  • May 2013
                                  • 2161
                                  Re: Lg32ld490
                                  so does that mean i need a Logitech Harmony Remote to access the service menu ?
                                    Re: Lg32ld490
                                    If you look on that list, there's many options. One of them involves using an audio output (e.g. laptop, iPod, phone) and an IR LED - if you can get the bits from CPC it could work.
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      Re: Lg32ld490
                                      can you still ask your friend if he wants to sell his main board as well tom pls
                                        Re: Lg32ld490
                                        I will give him a call tomorrow and check, he runs a TV/laptop repair shop. He'd probably sell the whole set of boards for cheap, will check with him.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • reassor
                                          Sony kd70xf8305 very very slow android logo with sound
                                          by reassor
                                          Hi.
                                          Power is ok
                                          Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                                          Should i force update? If so how?
                                          I did reset.
                                          Mainboard Looks pristine.
                                          Very wierd.
                                          10-30-2023, 05:59 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
