Magnavox 40MF430B/F7 Wont power on
  • simcole
    • Apr 2014
    • 30
    I had a TV given to me recently and it was a Magnavox 40MF430B/F7
    It has a blown main fuse (250v 8A) and a couple blown diodes. I'm ordering some replacement parts from Digi-key but I'm having trouble cross referencing some of my parts. ALL of the parts listed in the service manual aren't sold at digikey by part number. I'm having to put in what information I know and try to match it up. Some of this is VERY confusing.
    Here is the service manual:
    On page 71 I need 2 diodes. D1202 and D1203.
    Code:
    D1202# DIODE 1N5397BD NDL1001N5397
    D1203# DIODE 1N5397BD NDL1001N5397
    Closest thing I can find on digikey is this. Will this work?
    My other big question is cross referencing this item: FCHS20A08
    It's also on the page 71 on that manual as item D1721
    Code:
    D1721 DIODE SHOTTKY FCHS20A08 QDWZCHS20A08
    Digikey sells this item that's close..
    If y'all can help me find these comparable parts hopefully I can get this thing running.
  • R_J
    • Jun 2012
    • 9624
    Re: Magnavox 40MF430B/F7 Wont power on
    The schematic shows them as 1n5406 General purp. 3A 600 v diode, digikey has them, or 1n5397 gen. purp. 1.5a 600v diode, they have them also,
    whats wrong with the fchs20a08, is it shorted? being a shottky it will diode check at a lower reading on your meter compaired to a regular silicon diode, si checks around .7 and the shottky around .2 - .4
    • simcole
      • Apr 2014
      • 30
      Thanks for the diode info. I'm confused on some of that stuff. The spec sheets not using the same terminology as digikey really makes it hard for me.
      The fchs20a08 checks open on my diode test of my mm. I'm getting normal drop when I test from both anodes to the cathode. When I reverse the lead and put the black on anode and red on other anode I get tone. I also get tone if I move red to cathode, so I belive it's failed. I did not remove it from the board to test. None of the others test like this. This is my first schottky diode.. can someone agree with me here so I know I'm diagnosing this right.
      I'm told a common problem with the main fuse popping on these boards is due to those type of diodes. We're you able to cross reference that part for me too? I appreciate the help.
      • R_J
        • Jun 2012
        • 9624
        Were D1202 d1203 Shorted? if they were, replace all 4 diodes in the bridge, D1201,1202,1203,1204.
        To check the fchs20a08 the meter must be on DIODE test don't worry about the tone, with the black probe on the cathode and the red on either anode you shoud read about 180 (+ or - depending on meter) when you reverse the leads it should be higher, but because its in circuit the meter will charge the capacitor for that circuit and the meter reading will be off. leave the leads connected and see if the reading climbs up. Like I said, I dought that that diode is bad.
        I would also check IC1201 pin 5 to 7-8 make sure there is no short between those pins, if there is then the ic is also shorted.
        • simcole
          • Apr 2014
          • 30
          The IC1201 tests good. It's not shorted out.
          The diode 1208 was actually blown out on the side. In a service manual update it says that this is common and to just remove this diode and not replace it.
          As for diodes 1202 and 1203 they show no signs of blowout. They just pass 100% of the voltage both directions.
          Finally after testing the fchs20a08 using your method, I did get a .217 reading from either anode to the cathode. Once I reversed the leads it climbed up like you said. I thought the point of these type of diodes were that I COULDN'T pass the voltage that direction. That's why I thought it failed.
          Edit: Page 29 of that manual applies to me. If the fuse blows out, use flow chart #2.
          "Check the presence that the primary component is leaking or shor ted and service it if defective."
          or
          "Check the presence that the rectifying diode or circuit is shorted in each rectifying circuit of secondary side, and service it if defective."
          What latin is this? Hence why I said I thought the rectifying diode might be bad.. it's the biggest heat sink on the board.
          • whatusername
            • Dec 2013
            • 456
            Thread revival..
            I have the same issue blown fuse saw the bulletin on diode 1208 will remove but just wanted to know how this issue was resolved
            • whatusername
              • Dec 2013
              • 456
              Problem solved.. Ordered the repair kit from shop jimmy and installed 8 diodes and 1 ic and a fuse and the tv works.. if you do this repair make sure to leave the diode d1208 disconnected it comes with the kit but i didnt use it as per the bulletin
              • asr
                Finding replacement diode iPad Pro 3rd gen A1701
                by asr
                Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                07-09-2024, 06:24 PM
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
              • Baste
                MBR3045CT and SR3045LCT Schottky diode testing help.
                by Baste
                Hello experts,
                Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                Aneng ST182 Meter.
                Diode mode.
                MBR3045CT:
                Diode mode
                Pin 2-1 - 0.150v
                Pin 2-3 - 0.150v ...
                10-21-2025, 06:14 AM
              • NicRac
                monowheel repair,Is the diode the problem?
                by NicRac
                Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                First of all, I am new here. Therefore I will shortly introduce myself.
                I am Nico and currently I study Physics.
                In my freetime I like to build and repair stuff. Especially big battery's.
                A few years ago I got myself an electric unicycle, monowheel or however you call that.
                The battery bms was broken so I replaced and resolder that. Nothing big.
                I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                07-26-2024, 06:13 AM
              • dennis_elx33
                NO BODY MARKING Diode
                by dennis_elx33
                Hello Everyone,
                I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                While compared to the reading of another diode from the next channel it won't read at reverse bias.
                Now the problem is; it does not have any body marking.
                So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                What do you think is this diode?
                Can you please suggest what part number can i use to replace this faulty diode instead?
                Hoping that you...
                06-14-2024, 12:36 AM
