service mode philips tv 19pfl3505d
  • t.j.
    • Apr 2010
    • 383
    • canada
    tried the 062596 info/menu ways an they dont take me there! is there a differ way that anyone knows of?
  • R_J
    • 9588
    Re: service mode philips tv 19pfl3505d
    How to set up the service mode:
    Service mode:
    1. Turn the power on.
    2. Press [MENU] button to display Setup menu.
    3. Select “Features”.
    4. Select “Current Software Info”.
    5. Press [0], [6], [2], [5], [9], [6] and [Info] buttons on
    the remote control unit in this order.
    Just Google for the service manual
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      R_J you are correct,I tested it on mine and it works.
      Any way to see how many hours it has been on,how many times turned on/off etc?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • t.j.
        • Apr 2010
        • 383
        • canada
        tried that an no go! will try again in morrow, thanks guys.
        • t.j.
          • Apr 2010
          • 383
          • canada
          ok got it, was not holding buttons long enough! reset did not help, having sound issues with it, all sources . have to crank it to like 35 to hear speakers an they are garbled somewhat an just don't sound right!will open it in morrow! thanks again/
          • AustinCER
            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
            by AustinCER
            Hello, I currently have a Dell XPS 8940 in our office for repair.
            Service Tag: HG1Y673
            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
            07-15-2025, 05:28 PM
          • RRice25541
            Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
            by RRice25541
            So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
            the color is all outa wack, like the settings have been corupted,
            I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
            so
            The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
            when i bring up the menu and type the pass codes to access either mode the menu disappears...
            05-13-2022, 10:44 PM
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • thesame
            JVC LT-40V750 stuck in service mode switching colors.
            by thesame
            The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
            01-12-2024, 10:39 AM
          • HP32Sii
            Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
            by HP32Sii
            This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
            The set came into my possession by accident,...
            02-26-2023, 10:00 AM
