service mode philips tv 19pfl3505d
  • t.j.
    • Apr 2010
    • 383
    • canada
    tried the 062596 info/menu ways an they dont take me there! is there a differ way that anyone knows of?
  • R_J
    • Jun 2012
    • 9624
    Re: service mode philips tv 19pfl3505d
    How to set up the service mode:
    Service mode:
    1. Turn the power on.
    2. Press [MENU] button to display Setup menu.
    3. Select “Features”.
    4. Select “Current Software Info”.
    5. Press [0], [6], [2], [5], [9], [6] and [Info] buttons on
    the remote control unit in this order.
    Just Google for the service manual
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      R_J you are correct,I tested it on mine and it works.
      Any way to see how many hours it has been on,how many times turned on/off etc?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • t.j.
        • Apr 2010
        • 383
        • canada
        tried that an no go! will try again in morrow, thanks guys.
        • t.j.
          • Apr 2010
          • 383
          • canada
          ok got it, was not holding buttons long enough! reset did not help, having sound issues with it, all sources . have to crank it to like 35 to hear speakers an they are garbled somewhat an just don't sound right!will open it in morrow! thanks again/
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • tusiime
            How to access Vizio m652i-b2 service menu
            by tusiime
            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
            09-15-2023, 09:57 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • alltvrepairs
            Jvc Lt-65VU3000 reduce backlight from service menu
            by alltvrepairs
            I have just replaced led set of this vestel tv due to age.
            I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
            Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
            Thanks again....
            09-20-2025, 05:03 AM
