Insignia NS-LCD32 Vertical Red Line
  • n1iwv
    • Jun 2013
    • 20
    Hi All:
    I think I know what the problem is, but I just wanted to run it by the resident experts to confirm my suspicions.
    The problem is that I have a single red vertical line on the screen
    It appears to be 1 pixel wide.
    So far I have cleaned all the ribbon cables and connectors on the T-Con board as well as the connectors on the "Tab board" the runs along the bottom of the LCD panel.
    I've inspected that tab bonds to the LCD panel and see no obvious signs corrosion of breaks in the ribbon cables.
    Pressing on the ribbon cable in the area of the red line does not make any changes to the image or the line.
    Is this LCD panel bad?
    Other than the red line, the TV works fine.
    Is there any other things I should try?
    Ed
    Re: Insignia NS-LCD32 Vertical Red Line
    Most likely it's a bad LCD panel.
    • n1iwv
      • Jun 2013
      • 20
      Thanks for your reply Tom.
      I thought that might be the case.
      It's still useable as a computer monitor.
      Thanks again
      Ed
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
      • mrsith
        Samsung UE58TU7100K - no picture, vertical line
        by mrsith
        Hi.
        Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
        This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
        Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
        02-07-2023, 11:18 AM
      • bdalkiran
        55EC930V white vertical line appeared (need help)
        by bdalkiran
        Dear All,
        I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
        Please advice how to proceed and what is the...
        01-13-2023, 04:16 PM
