Hitachi 42EDT41 No Picture
  • CraigR
    • Dec 2013
    • 959
    Hitachi 42EDT41 Plasma Has amber standby light push power button and it turns green and I can hear solenoid click in back but nothing on screen. I checked VS and VA voltage and VS is 3.8V and VA is nothing. I was told the power supply board is new.
    Re: Hitachi 42EDT41 No Picture
    Check VSAGO, VCEGO signals on connector going to power board (should be labelled.) They must be high (>3V) for it to work.
    • CraigR
      • Dec 2013
      • 959
      What stinks is that on the power supply there are no markings next to the connector just what connector number is.
        Oh, I didn't notice this was an LG panel. 42V6, 2004 panel, 480p... is it really worth fixing? Anyway, try isolating the Y- and Z-sustain boards. See what happens, Vs rises or not?
        I have vague recollection of fixing one of these. Top left corner one of the ceramic resistors was open circuit.
        • CraigR
          • Dec 2013
          • 959
          Only going to fix if it's cheap. Anyway I did get normal voltage with the Z-SUS disconnected.
            OK you probably have a shorted Z-sus IPM, I would look for a replacement Z-sus.
            • CraigR
              • Dec 2013
              • 959
              Well got the Z-sus and same exact thing $45 wasted any other thoughts?
                Well, are you sure your replacement Z-sus is OK? Is it shorted? $45 on this TV? I get given these for free in working condition.
                • CraigR
                  • Dec 2013
                  • 959
                  I was told it was tested and in working condition. I checked VS and VA to ground and it does not seem to be shorted. Unless you can tell me another way to check.
                    VS/VA bad with Z-sus connected means the Z-sus is short; sometimes the short can be hiding behind a component like a diode and so is not easily visible.
                    • CraigR
                      • Dec 2013
                      • 959
                      Any point to check directly on the board for a short?
                      • CraigR
                        • Dec 2013
                        • 959
                        Could a bad panel cause the same issue?
                          Bad panel, I have never heard of it on these.
                          If Vs/Va is gone when Z-sus is in, the Z-sus must be shorted somehow.
                          These are very dumb plasmas - almost anything can go wrong on the sus boards and they'll do their darndest to keep working...
                          • CraigR
                            • Dec 2013
                            • 959
                            Hmmm, would have thought a fuse would blow if something shorted.
                              Fuse will only blow if the current through it exceeds its I^2 * T factor (something like 5 amp will blow a 1 amp fuse in 1 second, 10 amp will blow it in 1/4 second, etc.)
                              If the power supply can't supply that fault current the fuse won't blow, simple...
                              • CraigR
                                • Dec 2013
                                • 959
                                so look for another Z-sus board then I guess.
                                • CraigR
                                  • Dec 2013
                                  • 959
                                  Ended up junking it out after another Z did not fix it.
                                  • KYBOSH
                                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                    by KYBOSH
                                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                    No picture but you hear the TV static (white noise) playing loud and clear.
                                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                    But it seems they didn't get too far and just left it.
                                    When I first took a look I was amazed at how pristine the inside looked.
                                    Its as if the TV had been in a time capsule.
                                    Caps looked like they were just pulled off the self.
                                    Copper coils had no sign of corrosion on...
                                    02-01-2023, 11:10 PM
                                  • Tr0ll
                                    by Tr0ll
                                    Original T-con:
                                    First replacement T-con:
                                    10-07-2023, 07:48 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JackUzi
                                    HITACHI 55HK6T64U Picture ghosting and jumping
                                    by JackUzi
                                    First post so please bear with
                                    So I found a similar issue on another thread but have been advised to open a new one so here it is.
                                    One day this TV started doing this:
                                    https://www.youtube.com/watch?v=42QlTOSOCjw
                                    This happens on all inputs and menu screens.
                                    Thank you to nomoresonys for previous advice - to check voltage on powerboard connector and possible loose/bad tab bond.
                                    I've opened it up and tried reseating all the ribbon connections but the problem remains. I need some support in testing...
                                    11-23-2023, 06:47 AM
