Problem with Vizio L30e
  • antiquim
    • May 2007
    I have a Vizio model L30e. The problem started a few weeks ago, every once in awhile the picture would shut off but the tv itself would stay on audio still working. After a few times of doing this now the picture doesn't come on at all but the tv still powers on and has sound, the screen does light up at first also when first powering on only to return to total blackness. I was wondering if this could be bad caps? I called Vizio and they said it was probably a problem with the video board or power supply but I really don't want to spend $250 to repair something that I could do myself for a lot less. Any help is appreciated.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Problem with Vizio L30e
    shine a flashlight on the screen to see if the pic is there but the ccfl quits.
    i get these every now and then at sams in their return dept.
    bad soldering and a fouled lcd connector top the list so far.
    one type with black boards with logos that look like boat sails runs so dammed hot i doubt the capxons will last a year.i measured 155 f with an ir meter WITH THE BACK OFF!
    • roadrunner
      • Dec 2008
      I saw your post for a L30e and have the same problem with no video. Can you give me some idea as to what connector may be bad and a good start to what solder connections may need resoldering. I was given this tv and have an electronics background but I'm not a tv tech, however I used to repair test equipment coming off the assembly line. I have the board off the back where all conncections are made, is this the board we are talking about. Thanks for any help you can give me.
      Rich
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Thanks KC.
        Been wondering about Vizio.
        Mann-Made Global Warming.
        - Dr Seuss
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • rajbot
          No Power problem with Vizio E60-E3
          by rajbot
          Hi all:
          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
          03-22-2023, 08:09 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
