help with this capacitor
  • mattstolte
    • Dec 2013
    • 612
    • usa
    ok so this thing is swollen and looks like it needs replaced correct? it is the main cap off polaroid 32 IN LCD TV POWER SUPPLY, BUT IT SAYS 150UF 450WV, I CANT SEEM TO LOCATE ONE OF THESE? ANY HELP
    Re: help with this capacitor
    What is the diameter and the length?
    • Shinju
      • Mar 2014
      • 1239
      Some of those caps have a plastic dome top that makes the cap look like its bulging on top. If you can peel back the cap wrap and pop that plastic piece off the top and see if its leaking.
      I have worked on several car amps that have those plastic dome topper caps and they have all been fine.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        thanks, I did that its not leaking
          Is it bulging or completely flat? If it's flat then the cap is probably OK. You can use ESR/cap meter to be certain.
          • wills123
            • Jan 2014
            • 72
            • england
            i just replaced same cap on a ipos 150 board, 150uf 450v, only place i could find one was ebay but im uk, maybe usa ebay has one
            • mariushm
              • May 2011
              • 3799
              Keep 450v, use 150uF or higher.
              Examples:
              http://www.digikey.com/product-detai...378-ND/3134334
              http://www.digikey.com/product-detai...379-ND/3134335
              http://www.digikey.com/product-detai...200-ND/2600242
              http://www.digikey.com/product-detai...355-ND/3134311
              http://www.digikey.com/product-detai...199-ND/2600243
              http://www.digikey.com/product-detai...201-ND/2600245
              Check diameter and height and you're good to go.
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
