Plasma screen issues
  • Der3wuste3fuchs
    • Feb 2014
    • 5
    • U.S.
    Model: Hitachi Ultravision 42HDS69
    Equipment: PS3, connected to HDTV via HDMI
    TV Video Settings:
    Picture Mode: Day (Dynamic)
    Contrast: 53
    Brightness: 48
    Color: 30
    Tint: 5 clicks towards Green
    Sharpness: 30
    Color Temp: High
    Black Enhancement: Off
    Contrast Mode: Normal
    Noise Reduction: Off
    Auto Movie Mode: Off
    PS3 Settings:
    Video Settings
    BD/DVD Cinema Conversion: Automatic
    BD/DVD Video Output Format: Automatic (uses Y Pb/Cb Pr/Cr)
    BD 1080p 24Hz Output (HDMI): Automatic
    Display Settings
    Video Output Settings: Current Output Resolution 1080i
    Cross Color Reduction Filter: On
    RGB Full Range (HDMI): On
    Y Pb/Cb Pr/Cr Super-White (HDMI): On
    Hello all, first of all wanted to say glad to be here, the forum seems very active and welcoming.
    I recently got an older model Plasma TV, I got it on the cheap and everything seemed to be working fine.
    However, after getting used to the TV, playing with the settings and noticing small things there are a couple things I'm assuming are either failing or that are associated with burn-in.
    Whenever there are scenes where there is a lot of motion and fading or shading, it transitions the different shades and hues very poorly giving off a rainbow effect. Also, there will be a fine grain "mist" of particles, mostly dark or black that pepper into some of the lines. These grainy streams seem to happen more frequently on start-up and in contrasting shades (after it warms up).
    I've tried a couple of plasma burn-in fix videos on youtube. Not sure if they're helping but I've had some sit for a few hours.
    Any help would be appreciated. I'm a technician for the millitary so I am used to troubleshooting and even though new to the plasma game, I would like to understand and actually fix the TV. I would really like to try fixing this guy as I think this TV can have a very nice picture.
    1st Image with "grainy effect"
    [img=http://s21.postimg.org/9l8yeg5mr/image1.jpg]
    2nd Image with "rainbow effect"
    [img=http://s29.postimg.org/zfvij8e5v/image_2.jpg]
    In the second image there is also a vertical rainbow effect that is tighter, but this is just the iphone camera.
    I try to be as descriptive as possible so if there's anything else you're wondering please let me know.
    Thanks for taking a look!
    Ian
    Re: Plasma screen issues
    What you are seeing is known as plasma dithering and is completely normal for a plasma. It is generally more visible on older models but the general rule is if it is not visible at the ordinary viewing distance it is not a problem.
    Plasma panels are truly only capable of displaying fully lit pixels and fully dark pixels; dithering is one technique amongst many others used to improve the colour depth. It's a pattern which is designed not to be visible to the human eye at normal distances and on normal moving images.
    • Der3wuste3fuchs
      • Feb 2014
      • 5
      • U.S.
      Thanks for the quick reply Tom.
      I am about 7-9 ft away from the TV. Is this still normal? Guess maybe I'm just being too picky and not getting my settings right. Still don't feel like I have that "picture".
        It's an older plasma. It probably is a case of "being picky". I have a 46" Panasonic PZ80 and I can just about see it around 2~3ft from the screen, and I have 20/20 uncorrected vision; I do remember seeing a friend's Pioneer Kuro and they had pretty bad dithering on the older models. I think it's just something you'll have to live with for an older TV like this (2006 model?) Processing on plasmas has got a lot better now. Also remember that the Hitachi is probably only 1024x512, with the vertical resolution effectively doubled by the ALIS display to 1024x1024. This means the dithering will be a lot more visible than a true full HD panel (1920x1080.)
        • Der3wuste3fuchs
          • Feb 2014
          • 5
          • U.S.
          Yes, you are correct on all bounds. 2006 model and the 1080i opposed to 1080p I'm sure does make a difference. I put a little more effort and looking at it and the fine grain noise (hard to describe) doesn't seem to be normal. I've heard of this being a problem with TV's that have a failing power supply?
            What you have also highlighted is characteristic of certain MPEG encoded videos. Try playing back video from a pure analog source such as over-the-air TV (not through a digital box.) This is banding because the video is reduced from a pure 4:4:4 source to a 4:2:2 source, the colour resolution is halved. Also you are dealing with 8-bit video; there are only so many quantisation levels available to display colour gradients. I imagine if you try this on an LCD, you'd see nearly the same effect.
            A more severe issue than you describe is often caused by the plasma panel aging, but it's typically expressed by random misfiring pixels and pixels continuing to discharge after a portion of the image has gone dark. It's not usually as subtle as you indicate. It can sometimes be corrected.
            BTW, the TV is not 1080 aside from it having 1080 vertical lines. It does not have the required 1920 horizontal lines to display a full HD video signal. A more accurate description would be 720p, as that is what it can display as a maximum resolution.
            • Der3wuste3fuchs
              • Feb 2014
              • 5
              • U.S.
              I guess that would make sense. All of my viewing is from digital sources as I don't have cable. I guess I can get an antennae and see if it's the same. Just wondering though.. Why would there be noise when watching, say, a standard movie (5th element); as opposed to when I watch an animation (such as Archer) and the picture looks fine?
              • jeewantha
                Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
                by jeewantha
                Dell Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
                I already write 2 bios files. For both files it is not on.
                Only light up top cover LED..
                Machine Model : Dell Venue 10 Pro 5055
                Service Tag: GWV0G32
                Board Model Number : SILVERTON MB
                14238-1
                WX4XD
                Please help to fix this problem. ...
                06-22-2024, 09:54 AM
              • RetroComputingGrotto
                New Toy UNI-T UTi260B - What Settings?
                by RetroComputingGrotto
                I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                09-02-2025, 08:36 AM
              • i440bx
                Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
                by i440bx
                Hey there,
                I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
                The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
                It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
                As written above, I plugged in a new CMOS cell and checked...
                08-19-2024, 02:28 PM
              • gretti
                MSI Z370-A Pro, works but does not power off or reboot and USB issues
                by gretti
                I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                The MSI BIOS included the ME firmware for the board. The size...
                10-16-2025, 02:14 AM
              • rutgerv
                Acer Swift 3 SF314-42 not powering up
                by rutgerv
                Dear all,
                For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                The issue with the Acer laptop is the following:
                It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                08-02-2024, 06:59 AM
