General question about lvds
  • topng
    • Dec 2013
    • 56
    • ISRAEL
    hi all
    i read on lvds in wiki and some books .
    i searched the forum and could not find an answer
    can anyone explain how to identify the lvds types
    and the differences between them ?
    thanks for the helpers .
  • triplefour
    General question about LVDS voltages. Blank Backlit Screen.
    by triplefour
    im trying to understand how mainboards send data to tcons and tcons send data to panel boards and how panel boards control the panel itself.
    but starting at the beginning: if i have a tv with symptom: blank backlit screen, i want to verify if the mainboard is functioning properly first. its easy to see if its sending 12v to the tcon...but im pretty foggy on what the other lines of the LVDS connector should have on them.
    and also should they have the same voltages on them regardless of if the t-con is connected?
    and also how do you probe these pins easily? they are...
    12-18-2022, 02:45 AM
  • NolesFan
    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
    by NolesFan
    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
    10-24-2024, 06:36 PM
  • abajor
    A2141 Repair Wiki Error
    by abajor
    Not sure if anybody here is a repair wiki editor but
    https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
    It makes the erroneous claim that "LEFT SIDE TOP PORT IS CONTROLLED BY U3100"
    It is not. Just looking at the USB jumper connections on a board View will confirm this, or just remove U3100 and see that the top jack still powers at 5V and the bottom jack is now dead.
    Also what does top and bottom even mean when they're both in the same plane. Forward and Rear make more sense.
    09-02-2025, 10:46 AM
  • lpraderi
    Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
    by lpraderi
    Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
    In some cases to use LVDS screen PCB use converter IC RTD2132/6
    Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
    at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
    Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
    11-25-2023, 09:31 AM
  • TCCTech
    HP Elitebook LVDS port
    by TCCTech
    Hi all, I appreciate any help at all on this I have an HP Elitebook 840 a customer spilled tea on it and it shorted/melted the LVDS port I found the schematic here
    file:///E:/Users/BBB/Downloads/HP%20EliteBook%20840%20-%20ZBOOK%2014%206050A2559101-MB-AX1%20COMET%20DIS%20SI2%20Schematics.pdf
    But i can not find the part number for the LVDS port if anyone knows where I can get a LVDS port I would appreciate it. Every time I google it I get lots of LVDS cables but not the port/connector.
    Thank you in advanced...
    09-02-2022, 05:18 PM
