Whoops-Shorted out SMPS by accidental probe slip
  • ALR
    • Nov 2012
    • 111
    So, Title says it all.
    I got a free TV today, Element ELCFW328. Worked fine for about 10 minutes and would shut down to completely back to standby and would then, turn back on with no issues until about 10 minutes later.
    Went to checking some voltages on the connectors and I believe my probe touched the standby and 12v.
    No, no standby voltages but the other voltages seem okay.
    Tested Diodes and D16 on the cold side is really the only one that wasn't right in circuit so took it out and it's reading 0.201v in Diode Mode.
    This is the board
    ay118l-4hf01
  • Ltank
    • Jun 2013
    • 776
    Re: Whoops-Shorted out SMPS by accidental probe slip
    I viewed the pic but could not see where the damage was. List the make and model of set and part # of the power supply and a close up of the damaged parts
    • daveryder
      • Nov 2014
      • 13
      Hi I know this post is old, but I am trying to fix the exact same PS, and comparing your board to mine, the part labeled "T1F" on your board looks completely melted. Don't know if that helps or if you even care anymore, but thought I'd give my 2 cents worth.
      resistance is futile
      • Axis937
        Accidental slip of the hand caused a spark on Capacitor. Is my PANEL killed in action?
        by Axis937
        Hi folks, newbie here. My intention on a working monitor was to test for voltages on the various pins. Somewhere near the ribbon to the monitor, there we 2 caps. One was reading around 5V and the other was maybe about 12 or 14V . Cant really recall. Then it happened. The multimeter kissed the 5v cap and the other cap. Spark appeared. NOW... the part where the spark happened ( Caps near the Last ribbon cable ) is now totally white. 1/6 part of the screen is white. From my little understanding , i came to learn that there are transistors inside the TFT panel. Could that be a issue then? I have removed...
        11-10-2024, 06:50 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • dkneyle
        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
        by dkneyle
        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
        02-01-2022, 02:08 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
