Having troble running 1080P channels
  • 120volts
    • Oct 2013
    • 57
    PLUS NO COLOR
    DAN
    Dan "TV Tinkerer"
    Re: Having troble running 1080P channels
    You need to get a colour filter and that should also give you HD digital programming.
    • FALKLAN
      Running Line Voltage and Integrating LED Pods - Automotive
      by FALKLAN
      Howdy everyone! I hope all is well where ever you are!
      I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
      I am uncertain how to convert this line into a switched 12v output line for the LED pods....
      02-05-2025, 12:30 AM
    • r2digital
      Harmon Kardon AVR340 no sound on 4 channels
      by r2digital
      Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
      03-09-2024, 01:33 PM
    • rustinjust
      Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
      by rustinjust
      My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
      The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
      It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
      I have to turn the tv off and then on again with...
      09-28-2023, 12:23 PM
    • rumpumpel1
      ThinkPad X1 Carbon 4th Gen running only at 400 MHz
      by rumpumpel1
      Oberservation:
      X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
      In rare cases (1 out of 20) it runs at normal speed.
      It does so when running on battery or only with the charger.
      When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
      The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
      Flashing CleanME and a different BIOS made no difference.
      Intel's XTU utility...
      09-18-2023, 06:13 AM
    • Kambi13
      Samsung NP370E4K No backlight running on battery
      by Kambi13
      Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
      Tried different battery - no change
      Tried different screen - no change
      Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
      09-04-2023, 11:06 AM
