Samsung LNT4042H Capacitor replacement
  • putznik82
    • Apr 2014
    • 8
    • US
    I've already identified the busted capacitors but have no idea what to replace them with or where to purchase. I'm new to this level of electronic repair, any help is appreciated!
    I tried attaching a closeup of one of the caps, and a shot of the group of them.
    Thanks!
  • Ltank
    • Jun 2013
    • 776
    Re: Samsung LNT4042H Capacitor replacement
    Do you mean broken off or bulging or leaking capacitor? The uf and voltage should be written on it somewhere. I see 1000 mico farad 10volt Caps at the forefront. Caps can be brought at Mouser or Digikey or ebay. Shipping will cost more than the cap. Be carefull not to damage the foil where the leads are soldered. Make sure the solder is molten when pulling the cap. U-Tube shoild have videos on how to unsolder and solder caps.
      Buy them from Digikey.
      Just type "1000uF 16V fc" for example in to find Panasonic FC-series 1000uF 16V capacitors.
      • MEB
        • Sep 2013
        • 371
        Go online to mouser.com. Type in capacitor. From dropdown choose Al electrolytic. From there enter what you know. You want 105 degree C and the capacitance and voltage are on the cap. Other choices are cap diameter, length and lead spacing. I like Panasonic. You want low esr. Have fun. Same thing with Digikey.
          Spec sheets, find the value and the size that will fit your board then type in the PANASONIC P/N in DIGI-KEY search box.
          I.E. FM series 1000uF 16V P/N is EEUFM1C102 search box
          then this is what you get:
          http://www.digikey.com/product-detai...2366-ND/613727
          • putznik82
            • Apr 2014
            • 8
            • US
            Wow, you guys are amazing. Thank you very much. MEB, I did exactly as you prescribed and they should be on their way here soon.
            Thank you again all very much for your replies!
            • MEB
              • Sep 2013
              • 371
              Glad I could help someone, but everything I know comes from many days and nights reading the antics of budm and tom66 who also replied to you. They are the icons of this establishment. I'm just learning myself. But maybe if I can help you, they will have more time to help me!
                09-07-2024, 05:50 AM
              • artvandalai
                Where can I get compatible capacitor for replacement?
                by artvandalai
                Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                12-28-2024, 10:15 AM
              • NuclearSpartan
                Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                by NuclearSpartan
                I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                I don't see any other visible damage anywhere else on the board....
                11-14-2024, 02:32 PM
                09-06-2024, 11:40 PM
