Sony Bravia KDL-46V4100 power off itself
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony Bravia KDL-46V4100 power off itself
    So it comes on then goes back to just standby voltage
    • rustytierod
      • Sep 2014
      • 81
      Yes just changed caps. Same problem. Gonna try and change the ofhers.
      • dskall
        • Oct 2016
        • 2905
        • usa
        In post 10 are you getting those voltages for just a few seconds?
        • rustytierod
          • Sep 2014
          • 81
          Yes
          • rustytierod
            • Sep 2014
            • 81
            I didn't think it was a bad panel or drawing too much current because it does the same cycle with relays clicking on and then off even with just main board and power connected. Unless it exhibits the shutdown behavior if everything isnt connected?
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              You should have a connector for backlights and probably a bl_on terminal. No pictures I assume this is fluorescent backlights
              • rustytierod
                • Sep 2014
                • 81
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  To blurry, can you take picture of whole board
                  • rustytierod
                    • Sep 2014
                    • 81
                    Swapped in a pair of main and power from same exact model w cracked screen, same results
                    • rustytierod
                      • Sep 2014
                      • 81
                      Why would
                      52V4100 and 46V4100
                      Have different main boards? The part numbers are only off by one digit?
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • swrb898
                        Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                        by swrb898
                        What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                        Problem:
                        Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                        My troubleshooting got me this far:
                        With the left-hand TCON to bottom-board ribbon cable...
                        12-28-2021, 08:12 PM
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • PopsCaps
                        Sony Bravia KDL-40V2500 that will not power on
                        by PopsCaps
                        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                        I do not hear any sound and I cannot see any backlight.
                        I have tried disconnecting every cable on each board one at a time to see if anything changes.
                        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                        03-25-2025, 11:23 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
