Sony kdl52s5100. No picture no sound
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Sony kdl52s5100. No picture no sound
    So I found ph6501. And the legs read. The two on the left read 13v. And the two on the right side of it read. 3.39 and the bottom one -0.04.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Here is te pict of ph6501 on bottom and ph6502 on top.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        And now I think I just fried ph6302 the stand by voltage reg cause I was metering it and my hand slipped and touched the two right side legs. So the left side reads 6.49v and the other side doesn't read anything. Does that mean its fried and I need to get another one.
          If you look at the diagram, you will see the primary side where the LED inside the Opto is, what do you get if you measure right at the 2 pins of the LED side and the 2 pins on the photo transistor side. The Photo-transistor side is in the secondary cold side so the chassis is the ground ref point.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            are the two pins of the led side the side that has the diode inside of it or the other side that shows pins 3 and 4? Also I probably wont get any readings now because i fried the reg. for the 3.3v standby voltage.
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              #26
              At least I think its fried cause I get 13v still on the left side but nothing on the diode side.
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                #27
                So on the ac det photo transister. The led side I get nothing between the two pins. And on the pins on the right the diode pins I get 3.39v on the top pin and nothing on the bottom pin. And the 12v reg above it I get nothing on the led side the two left pins and I got 7.3v on the top right pin and 8.3 on the bottom pin. This the way I'm looking at it.
                • audiofreak19
                  • Apr 2013
                  • 556
                  • usa
                  #28
                  K
                  • audiofreak19
                    • Apr 2013
                    • 556
                    • usa
                    #29
                    I put my mm black probe on the single lead side of q6501 and the red side on one of the two pins on the opp side. Measured resistance of like 10ohms. Then did black on same spot and red on the other pin on the opp side and got 12 ohms. Then did black and red on the two pin that are on the same side and got 70 ohms. Does that sound like its bad. Lol I don't know the terminology for it but I found a test write up on the forum.
                    • audiofreak19
                      • Apr 2013
                      • 556
                      • usa
                      #30
                      Ok so I put my blk probe on the base of q6502 and red probe on the collector and got 4.07v. Then I put blk on base and red on emitter and got nothing.
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        #31
                        Ok I don't know what I'm doing someone help me in testing this circuit. Please.
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          #32
                          K
                          • audiofreak19
                            • Apr 2013
                            • 556
                            • usa
                            #33
                            G
                            • audiofreak19
                              • Apr 2013
                              • 556
                              • usa
                              #34
                              Here is a pict of q6502
                                "And on the pins on the right the diode pins I get 3.39v on" That is OK which means the BACKLIGHTS ON is not being routed to ground through the Optotransistor inside the OP6501. I am helping this OP on this thread which has the same power supply board as yours. He is getting the same voltage as you.
                                https://www.badcaps.net/forum/showth...461#post435461
                                https://www.badcaps.net/forum/attach...4&d=1396566313
                                So what DC voltage do you get at the BACKLIGHTS PIN?
                                • audiofreak19
                                  • Apr 2013
                                  • 556
                                  • usa
                                  #36
                                  I get .471
                                  • audiofreak19
                                    • Apr 2013
                                    • 556
                                    • usa
                                    #37
                                    But when I try to read it on the other side of the cable on the main board where the cable plugs in I don't get any reading at all
                                      So your Backlights on signal is also dead.
                                      • audiofreak19
                                        • Apr 2013
                                        • 556
                                        • usa
                                        #39
                                        Yea I'm assuming so.
                                        • audiofreak19
                                          • Apr 2013
                                          • 556
                                          • usa
                                          #40
                                          Is it possible to troubleshoot down to component on the main board for that or do u think its the chip in the main board
                                          • KYBOSH
                                            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                            by KYBOSH
                                            Previous owner said TV just went blank one day.
                                            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                            I just downloaded the Sony KD-75X7800F Service Manual and...
                                            11-19-2024, 10:12 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • ronni
                                            Sony KD-43XE8005 with sound, backlight, no picture
                                            by ronni
                                            I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                            When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                            Removing the LVDS cable results in...
                                            12-01-2022, 08:44 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
