Philips 42PF7321D/37 Plasma Seeking help and direction
  • mirador007
    • Mar 2014
    • 6
    • usa
    Hello to all,
    I recently joined the forum in hopes that someone can point me in the right direction.
    I own a 2006 Philips 42PF7321D/37 plasma which I rarely used, the set was operating fine with absolutely no issues and now the unit do not power on.
    I have searched, read and looked into the most common issues with this unit being the capacitors going bad and having to change them.
    My issue now that I have removed to back cover to expose all the PCB to exam all the common issues area and found all of the capacitors are perfect(visually) no bulging state.
    I also checked for any loose pins/connectors and any other obvious signs like burned out fuse and found none.
    I am suspecting at this point that the power supply board is burned out, if so what are my choices at this point?
    thank you in advance.
    P.S. unlike most common issues related to/with this unit I have had absolutely no issues prior to the unit not turning on at this point. Perfect picture, no blinking lights, audio is perfect. No tardiness on shutting off or on.
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Philips 42PF7321D/37 Plasma Seeking help and direction
    A service manual for your set can be found here you can follow the trouble shooting step to locate the failure. The good news is replacement boards for your set are available and are relatively cheap on shop jimmy.
    Liberating magic smoke one part at a time
    • mirador007
      • Mar 2014
      • 6
      • usa
      thank you, I have already DL the service manual and I'm getting my hands on a meter to check out the various readings from the transformer and capacitors.
      At this point I am suspecting the power supply board given that I had no standby light when the unit stopped working.
      I just wanted to make sure this was the issue before ordering the new board.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        OK, just be careful when poking around inside a plasma. Plenty of spots on the power board have several hundred volts present including the tops of some heatsinks. Happy hunting
        • mirador007
          • Mar 2014
          • 6
          • usa
          The power supply board has been removed and all the main capacitors have been discharged at this point. I'm just wondering if this is the real issue and not something else according to the service manual.
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            How did your voltage testing go? Usually if I have no standby power I start by checking all the fuses. If they test good test the bridge, then primary MOSFETs, then onto secondary diodes and MOSFETs. If those test OK start unplugging harnesses to see if I can get the standby to come back. I know this isn't set specific but a lot of the time the basic troubleshooting works.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Dunno if its the same set/PSU, but worth hunting out and replacing the cap, C2508, 100uF 16V surface-mount electrolytic, this causes the dead symptom many times on Philips Plasmas...
              TELEFIX
              • mirador007
                • Mar 2014
                • 6
                • usa
                thanks for the input Alastair E. I'm still in the process of checking out the all the Caps for their operating values. I have already located a replacement Power supply board just in case the issue is not related to the caps. There are plenty of refurbished around 45-99 shipped.
                • mirador007
                  • Mar 2014
                  • 6
                  • usa
                  Thanks to everyone for their input. I finally got around to testing all the CAPS and found 2 that were visually intact yet out of spec. Both of the replaced caps were well less than half of the uf rating. I was able to find the same value CAPS at Frys elect and replaced them with ease. The Plasma fired up with no issue ( so far ) I am currently going on 2 days with out any issues. The standby works fine, no delay in powering up or down.
                  Thanks again for the inputs.
                  • celiabrown
                    Issue with Plasma Philips 37inch chassis FTL2.1
                    by celiabrown
                    Hello guys,
                    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                    Can someone has any symptom like this ?
                    Thanks​
                    05-09-2024, 10:56 PM
                  • alro7779
                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                    by alro7779
                    Hello, guys!
                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                    09-14-2025, 12:25 AM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
                  • peterwang
                    Samsung NP750QGK-KG3US BIOS program error seeking help
                    by peterwang
                    PCB:BA41-03025A BA92-25486B
                    I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
                    08-14-2025, 08:15 PM
