Lg service menu 42ld420-za
  • munirutech
    • Oct 2013
    • 72
    • Ghana
    HI
    i'm trying to enter the service menu for lg 42ld420-za by using OK on the tv OK on the remote did not work i used MENU on the tv and MENU on remote also did'nt work, but if i use these method on older models they work,
    any ideas THANKS
  • vonbismarck
    • Mar 2014
    • 14
    • United States of America
    Re: Lg service menu 42ld420-za
    Originally posted by munirutech
    HI
    any ideas THANKS
    Hello. You can try this:
    Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
    LG Service Menu PIN/Password Codes
    8 7 4 1
    8 7 4 3
    7 7 7 7
    0 0 0 0
    8 8 7 8
    0 4 1 3
    I found this using the following site: http://www.factory-reset.com
    It lists ways to access the service menu for different brands though they don't always work for particular models.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • intercepter
      JVC LT-32CA120 service menu
      by intercepter
      I have JVC LT-32CA120
      Board:Vestel 17MB171
      I need rotate screen.It is possible in service menu and how to enter service menu?
      Thanks.
      12-10-2024, 10:29 AM
    • viewerau
      AVerMedia Ezrecorder ER310
      by viewerau
      I do hope I have posted this in the correct area, as it is a video related device?
      The above item has reached end of life, with the manufacturer not supporting this any longer
      My unit has stopped, in that it will start up, however, it will not respond to the remote control.
      My remote seems to work ok, as I can see it emitting a red led when I use a mobile camera to check it....just to be sure, I also have a Harmony remote 300 that I was able to download the codes onto, and it's behaviour is the same.
      Previously, pressing the remote invoked a...
      11-08-2025, 12:25 AM
    • alltvrepairs
      Jvc Lt-65VU3000 reduce backlight from service menu
      by alltvrepairs
      I have just replaced led set of this vestel tv due to age.
      I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
      Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
      Thanks again....
      09-20-2025, 05:03 AM
