Spectroniq PLTV-3250
  • nev1001
    What zener diode might fix the sound on Maestro Mayhem gaming chair?
    by nev1001
    Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
    The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
    It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
    I think an issue could be a zener diode (or capacitor) which has shorted out.
    The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
    04-17-2025, 05:09 PM
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • Astonished
    Fixing the Charge Circuit of the Batteries of the DC Motor
    by Astonished
    Hi friends of electronics
    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
    Please help me fix this circuit.
    (the datasheet of the IC: https://pdf.datasheet.live/28...
    01-28-2025, 06:24 AM
  • Tarot Superstars
    Short Circuit tester
    by Tarot Superstars
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
    09-25-2023, 09:11 AM
  • Alimash
    op amp circuit function?
    by Alimash
    I am repairing a ups which doesn't turn on ,it has the following ICs:
    SG3525 used to drive inverter mosfets.
    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
    A LM358 and TL074 for control mechanism and of course the uController.
    The SG3525 is shutting down every time the ups is turned on.
    I want your help to know the function of LM358 and TL074 in the system.
    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
    07-31-2025, 07:45 AM
